89eliminator Posted April 18, 2009 Posted April 18, 2009 lets get members to post their lift and tire specs and maybe put this into a sticky so that people can have something to base their decisions on what lift and tires to get. PLEASE ONLY POST THE PICS AND SPECS, NO CHIT CHAT. 6.5in coils, SOA with RC lift shackles 33x10.5 BFG, 15x8 rim
mvusse Posted April 18, 2009 Posted April 18, 2009 Front: 4.5" lift coils, 1.75" spacer, factory rubber insulator ~6.5" lift Rear: SOA with Ruff Stuff Specialties spring perches and stock re-arched 2" lift leaf packs totalling ~8" lift 33x12.50 tires on 15x8 rims.
jpnjim Posted April 18, 2009 Posted April 18, 2009 Pic hog post trimmed down..... 4.5" ZJ coils (6.25"), SOA 33's Same lift, 33x12.5" TSL's (33 5/8" x 11.5") & flares moved up: Poser Pic on 37's: Different MJ, 1" less lift (3" ZJ coils = 5.25ish) With Q/78's ft (35 5/8" x 10.5"), 37x13.00 Boggers rear:
MrSimon Posted April 18, 2009 Posted April 18, 2009 3" Motion Offroad MJ kit. 3" coils, 3" SUA leafs. 31 BGF M/Ts on Cragars.
JeepcoMJ Posted April 18, 2009 Posted April 18, 2009 6.5" RC coils and fully adjustable control arms RC quick-discos RE HD adj. trackbar SOA rear, 7.5" long perches. 33x10.50 BFG (have a set of M/T and A/T but both are pretty used...) Edelbrock Extreme IAC remote reversorvoir shocks all around
camjeep3 Posted April 18, 2009 Posted April 18, 2009 Rubicon Express 4.5(sent wrong coils. arond 3.5 4in.) rear stock Mj leafs with 4.5 xj aal sits level and has 31x10.50 ats
summerinmaine Posted April 18, 2009 Posted April 18, 2009 Since it's out of the mainstream, probably won't be too helpful but: Reported by PO: 4" Full Traction Lift in front (looks like their 3.5" with LCAs) Rusty 4" MJ springs in the rear (sagged after a year, but I don't hold that against them considering the load it's carrying) Skyjacker shocks JKS Adjustable Track Bar What I've done: Hellwig helper springs in rear 31x10.5 ProComps on 15x8" rims.
500 MJ Posted April 19, 2009 Posted April 19, 2009 Left: Stock 2wd 1990 MJ Right: 1988 4wd (Overall sits 11 3/4" Higher than the 1990 next to it) - 33" Yokohoma Geolander AT +2 Tires - (Front) 3.5" RE Coils - (2) 1" spacers - Modified XJ Clayton Longarm Kit - Dana 30 - (Rear) 4" Rusty's Leaf Springs with Stock Load Springs Bolted in - Aftermarket 1.75" Lift XJ Shackles - Dana 44 1988 Same stats - just with some OLD 33" Goodyear Wranglers for the winter months...
offroader461 Posted April 19, 2009 Posted April 19, 2009 6" Skyjacker coils, ACOS, RE drop brackets, SOA D44 rear 33x12.5 BFG A/T
Drahcir495 Posted April 19, 2009 Posted April 19, 2009 Rubicon Express RE6500 Extreme Duty MJ 5.5" Kit with Adjustable Upper/Lower Control Arms & Extreme Duty Track Bar Bracket Brace Rancho RS9000XL shocks ~ front with JKS Bar Pin Eliminators & upper Conversion Mounts 1997 Grand Cherokee V8 Sway Bar 33x12.50x17 Mickey Thompson MTZ Radial Tires on 17x8.5 Walker Evans rims w/3.5" BS
BJA814 Posted April 20, 2009 Posted April 20, 2009 RE 4.5" front lift with 2" spacers Rear spring over with stock 2wd springs 34x9.5x15 swamper tsl on 15x7 Needs to be trimmed, and drop brackets.
reson46 Posted April 20, 2009 Posted April 20, 2009 Front: 4.5" springs with a 1.75" spacer Rear: Spring over with Rocky Road extended shackles Tires: 35x12.5x15 Mickey Thompson Baja MTs Willy
mkbruin Posted April 19, 2011 Posted April 19, 2011 1989 SporTruck, 4x4, 4.0/ax15/231. Front: RE 4.5 ZJ coils, RE shorty LCA's, RE adjustable track bar, JKS BPE's, JKS quick disco's. Rear: SOA using no-name perches (picked up for ~$15/set), custom rear driveshaft (slip yoke) with high angle yokes. Tires in the pics were freebies (don't remember the size), rims were 16" For reference, she was 5'4".
Incommando Posted April 19, 2011 Posted April 19, 2011 Rough Country 4.5" coil front/AAL + Shackle rear (not recommended)32x11.5x15's on factory Gambler rims
ComancheKid45 Posted April 20, 2011 Posted April 20, 2011 Rusty 2" Coils + 1.5" spacer front Hell Creek XJ 2" AAL + Shackle rear :wrench:
Hubbell Posted April 20, 2011 Posted April 20, 2011 Rough Country 6.5" long arm lift, SOA, 16" Rubicon wheels, 285-75-16 goodyear MTR's
Dirteatr717 Posted April 20, 2011 Posted April 20, 2011 Here's 2" budget boost and 235s And here's same lift with 33s on a 15x8 rim, it's working fine as a daily driver except for the 3.07s and hills in 5th gear :ack:
Mjobession Posted April 15, 2014 Posted April 15, 2014 Bump. Just like what NewfieMJ said, I know its old but I think this is a cool thread
Blue XJ Posted April 16, 2014 Posted April 16, 2014 6.5" Rock Crawler 3 Link 6" Alcan SUA Leaf Springs 35" TrXus Mud Terrains on 15x8 American Racing wheels. Image Not Found
88whitemanche Posted April 16, 2014 Posted April 16, 2014 RE 4.5" coils Rustys adjustable upper and lower control arms Rear 3" aal And 32x11.5x15 BFG all terrains on 15x8 with 3.50" back spacing
mvusse Posted April 16, 2014 Posted April 16, 2014 Hope these work. They are hosted on Facebook and not taken by me. Don't know what the privacy settings are, nor can I change them. Looks a little different now than it did in the second post of this thread. Same lift as before (~6.5 front, ~8 rear), cut fenders to clear 35" tires: And currently, ~7.5" lift, 37s. Still a work in progress.
92tanMJ Posted April 16, 2014 Posted April 16, 2014 Image Not Found Lift- 0" Tires- 31x10.5/15 with 2" BS on stock XJ Rims Bump. As this is an awesome thread & I know of some people that still need to post. *cough* Pete *cough* ;) And a big thanks to everyone for helping me to decided what size tires to get....Hopefully I can post back this summer with different pictures
Jeepman Posted April 16, 2014 Posted April 16, 2014 1989 2WD Eliminator Converted to 4WD, New OE leafs SOA Rear on WK SRT8 D44 and 4.5" coils with ACOS Spacers adjusted to 2" on WJ front D30 which has the coil buckets 2" higher then a XJ/MJ/TJ D30, Rough Country long arm upgrade kit, Bushwacker flares and I am running 35x12.5x18 Mickey Thompson MTZ's Image Not Found
Pete M Posted April 16, 2014 Posted April 16, 2014 88 MJ with ~5.5" lift, 78 bronco 44/9", 33x12.5s on 15x8 steelies. front susp is ford radius arms, rear is SOA with some tired 2wd leafs plus a second main as an aal.
