camjeep3
    Fort Mill SC/Clemson SC
  • Interests
    Jeeps muscle cars...
camjeep3's Achievements
Comanche Addict
Comanche Addict (5/11)
  1. We look forward to the thread you WILL be starting! I grew up flying with my dad and grandfather. I am almost finished with my ppl. I have been in the back of a champ on a short hop once. I see the champ and chief as an airplane I might be able to actually own one-day!
  2. We need details on that project! I'm disappointed in myself I can't put my finger on what plane that is.... My best guess is a champ?
  3. I guess what I am getting at is why would you buy a unicorn or a collectable to be a driver when for the money we are talking you could get into something much more practical. But what can I say. I'm not the most practical either
  4. As much as I love a clean xj... 15-17k can buy a lot more vehicle than what is presented. If you plan to dd this will it still be a "mint, low mile" jeep in 5 years?
  5. You need to know what the thickness of the slab is and what the lift requires. Instal can be diy. You will need a decent drill to place the anchors in the slab. Everything else is nut and bolt assembly. Although heavy components. You will also need electric at the lift.
  6. Spill the beans already! What are the plans!
  7. Thanks Pete! Never thought about it but cc was relatively new when I joined way back when.
  8. No flames here! It's a valid question. Yes I am checking at the sensor
  9. Before I start throwing more ignition parts at it I want to at least confirm cause cps output
  10. Ohm. I will do that and report back. Eagle. Yes. I have the multi meter in the cps plug and on the hood while I crank. I have tried back probing and directly to the pins in the plug
  11. Swapped cps. No spark. No voltage at plug. Going to try a different meter to rule that out. But this is getting old
  12. After re reading my thread I realized the timeline and context of everything was confusing. At one point I did have good spark at the plug. But now I do not. I picked up a basic spark tester and fuel pressure gauge. Fuel pressure is good. No spark. That brings me back to the cps. The two o thought I ordered I never actually ordered. So those are on the way now.
  13. If you are looking for a square body truck I wouldn't limit yourself to the TBI years. There are multiple companies that make a TBI fuel injection that will drop in place of a carb.
  14. Ratrapp... You are 100% correct. And I already knew this I'm my head. The truck "ran when parked" was kind of my thought process going into this. But there has been a lot of time between now and then. I'm going to stop at hf after work and pick up the appropriate tools and start at square one. Thanks everyone for the help so far
  15. Sorry. There is context missing. The truck will no longer fire off on starting fluid. Fuel flow is there. After I replaced the tank and pump I blew the o rings out in the rail. I tested both cps with no voltage reading while cranking
