neohic
Moderators
    2
About neohic
    Woodland Park, CO
  • Interests
    Adventure!!
9261 profile views
neohic's Achievements
Obsessive Comanche Disorder
Obsessive Comanche Disorder (9/11)
  1. Welcome aboard! Such a rad truck.
  2. The suspension has been settling in just fine with that big ol’ top on it. Today’s project though was to swap out the spark plugs and diagnose the fuel gauge issue. The spark plugs looked okay(ish) but I also haven’t looked at them since the engine went in and lately it has been stumbling a little at startup. As for the fuel gauge, I thought about adding an inspection hole while I had the tank out, so I went ahead and added one. … almost in the right spot too! Unfortunately, the sweep mechanism is totally broken. Bummer.
  3. The rear diff cover started leaking so it got replaced today. Paint it black. Hit the track.
  4. Tough to read, but it still exists.
  5. MJ with an MJ: Up next is your truck at the car wash or getting washed:
  6. Welp… today is that time of year again to put the top back on. Unfortunately, I need to drop the new fuel tank due to the fuel gauge not working. That’ll be another day. I was a bit worried how the heavy top would settle on the new suspension, but so far so good.
  7. I’m assuming it was something from inside a fuel hose? When I took the filter housing apart, the icky black stuff was like a furry residue… I guess? Weird.
  8. Damn CJ left me stranded!… blocks from home. It had the same feel in the throttle like it was out of fuel that it’d idle but die when given any gas. So?… … glad I added a pre filter! There’s a 10 micron filter after the pump and I put in a 100 micron filter before that I could keep an eye on. Guess I should’ve gotten the three pack of filter elements at the same time! Not saying I’d be pleased if it decided to clog up two more filters right away, but theres backup elements in the console now.
  9. You know that fancy, new bed I just finished? You know that thing where you slightly rearrange your furniture and bad things happen? Yup… that happened.
  10. Back on the road and into its usual parking spot! I was worried that space would get tight under the floor but there’s plenty of room.
