Smokeyyank
2 Followers
    Littleton, Crawlorado
Smokeyyank's Achievements
MJ Junkie
MJ Junkie (6/11)
  1. Pretty much jeep ownership in a nutshell. I did this swap a few years after my rad crapped out. Overflow tank was about the hardest part and it wasn't that hard, rest just pieces together. I didn;t do anything special with the heather hoses and just connected them.
  2. Yeah 2 door kind of fugly, 4 door I don't hate as much. I do like their concept, think the slate did better with a 2door idea though.
  3. If cost isn't a consideration then 100% a portable hot water pressure but now your into the thousands. I'd be looking at bang for the buck but that is just me. I'd hold out for a HF coupon and get one of these or a smaller one. https://www.harborfreight.com/4400-psi-42-gpm-13-hp-420cc-commercial-duty-pressure-washer-epa-71102.html Otherwise just look around at something on sale local. https://www.costco.com/p/-/yard-force-3200psi-25-gpm-honda-gx200-196cc-gas-pressure-washer/4000309374 https://www.lowes.com/pd/SIMPSON-Powershot-3500-PSI-2-5-GPM-Cold-Water-Gas-Pressure-Washer/5014825463
  4. Next up is the Trailforged rear quarter panel. I already removed the metal and and everything dry fitted now just to install. Started on the driver side. When I was cutting out the old I took a little bit too much but will add in some more stitch welds and smooth it out. It will be covered by the bumper wing anyway so not visible. First was the new lower piece under the tail light. Then was the outer panel. Used the vice grips to then pull the middle section closer to flush Tacking All tacked in. Rear part burned in Passenger side was a lot better. Just need to burn in one more piece and then grind reweld. Next up is the rear bumper.
  5. Got the rear stiffeners finished up.Went back and ground the welds in some areas to fix them. Starting on driver side Finished with gusset in place Then finished up on the cut and fold, first cleaned up the area and removed the excess metal. Then spot welding the crap outta everything.
  6. Awesome! Welcome. Another rad red MJ to the CO mix.
  7. Nice! How was it piecing it all together?
  8. I got one from Costco years ago for a solid price. Mine is gas and I prefer gas over electric, but that's me. I've been snagging some of vevor's stuff lately and for the price hard to beat but not everything ahs been great of theirs. https://www.vevor.com/pressure-washers-c_11609/vevor-gas-pressure-washer-3400-psi-2-6-gpm-gas-powered-pressure-washer-with-aluminum-pump-spray-gun-and-extension-wand-5-quick-connect-nozzles-for-cleaning-cars-homes-driveways-patios-p_010834768806?adp=gmc&srsltid=AYCX9vKykJMOr1clk-zSFLzvOqoOStt_LIDNllLD0hZNvKP3epqVTiXBt-c There's always hobo freight too. https://www.harborfreight.com/2650-psi-24-gpm-56-hp-196cc-pressure-washer-epa-71098.html End of the season so some times can find clearance deals at lowes and home depot As for specs at least 2000 psi, gas or electric (I've had better luck with gas), tecumsech, honda, yamaha, honda, briggs and stratton all good engines.
  9. No corolla expert but Toyota are my dailys. I mainly get parts from the dealer (ironically it's cheaper for OEM parts there then some online places) otherwise rock auto works just get AISIN parts.
  10. I went with the Bambu for 99% of what your listed. I know people don't like the oversight and info that is pushed back to bambu but works for me. Just wanted something that could work out of the box and grow a little. Creatlity is decent too. I got this one. Went with the enclosure because I do want to print ABS and some other things and a enclosure is helpful. https://us.store.bambulab.com/products/p1s?from=navigation This model was the best for my price point and features. I was able to get it for under $500 at the time. You can spend big on a printer but from what I've seen it really just becomes larger printing area, speed and limited waste when you go up in price. Nice thing is the app and you can just got find a model and print it. I have learned to use the desktop version which I find is needed to make some changes to the model before printing. Not always, but I almost always add a brim to my print because of so many failures. When you want to scale something need the desktop version but it's not too complicated.
  11. I got a Bambu PS1 over the summer and have used it a bunch, a lot of fidgets, and stuff for the wife but working on useful parts. It pissed me off so haven't used it a lot lately, fn clogged nozzles and extruder issues. Favorite print has been @TDI_Manche tailgate key holder. Most useful prints have been some storage bins for the kids legos and trinkets, printed a camera holder for the wifes rear dash cam, printed a bunch of girl scout badges for the kids troop and some other things. Next I want to print a gridfinity system for the tool boxes and print some molle panels for storage items. I tried to use tinkercad and failed. Just don't have the time to want to learn it all right now.
  12. Sliders are done on both sides. Fully burned in and cleaned up (minus the pics). Few little things on both sides but good enough to move on to the next project, rear stiffeners. Absolutely love the finished look of the sliders. They are a ton of work but well worth it. Full tied into everything, welded to the bottom of the rocker panel. Was worried about poking holes in the sheet metal but no issues. After getting the sliders done, started on the rear stiffeners. This was a cake install in comparison. Few spots I didn't clean up as well as I should have and had a issues with my welds, but minimal issues. The difference between the trail forged and IRO stiffeners is wild. IRO is way thicker. I have the TF kit for the front and rear and it will be fine, but I'd only consider IRO for the mid stiffners. Need to go back and grind and finish up a few areas but not too much longer. After that will move to the rear bumper. I can't wait to be done with overhead welding, I already suck at welding and overhead is kicking my @$$.
  13. More rocker work. Got the passenger side pretty much done, few little things but overall solid kit before doing the driver side. Absolute @$$ kicker of a project but looks good. Started back with the inner rocker Then prepped the outer portion with primer and got them on. We're not gonna mention the $#!& welding in spots....... I need to practice with my machine more. All burned in
  14. I've used it more than a few times with jeep stuff. Does help me get info quickly or at least headed in the right direction at times. I mainly use gpt and claude but have used them all.
