GonzoTheGreat
3 Followers
    central MA
2706 profile views
GonzoTheGreat's Achievements
Comanche Aficionado
Comanche Aficionado (4/11)
  1. Quale parte d'Italia? Ho avuto una Cherokee a Torino. (Which part of Italy? I had a Cherokee in Turin.)
  2. Auto parts store (typical) A boat
  3. It is a power steering delete
  4. Cool. Ill message you my info and we'll find a weekend.
  5. I'm semi local, with intermittent wipers. You just need someone to plug them in and test?
  6. Seems like the crown ones are out of stock everywhere. Ive been trying to buy some of these and after waiting a month from quadratech (which now shows "out of stock") the lady there told me crown is currently looking for a new supplier. @jodawill please let us know if you manage to get ahold of these. @fiatslug87 I'll give those ebay ones a try and report back. The picture looks all wrong, but we'll see
  7. This thread has some useful, but slightly confusing information. Theres a specific way you need to eliminate the valve. You need to plug the distribution block bottom, front port, and make sure the front, front port (facing the front of the vehicle) runs to the T on the axle. Is this how yours is set up now? Another option, is to get an XJ or YJ distribution block and use that, because they never had these valves, but I'm not sure how the used parts market is in Sweden. Some guys on here prefer to eliminate the block, T in the front brakes directly to the master cylinder and run an adjustable proportioner to the rear. If the valve is eliminated correctly, and youre still having problems, i think youre on the right track playing with the pushrod adjustment.
  8. How did you bypass the load sensing valve? Also, pictures of any of the parts in question would help a lot.
  9. Not a huge project, but I was tired of leaving a puddle everywhere, and finally bought an aluminum valve cover with a silicone gasket.
  10. I had really bad luck with the doorman ones. After two years the rubber hardened, cracked, and caused leaks. I ended up using decent ones from a junkyard that werent as loose as my originals, but I am also interested to hear if anybody has found a better brand.
  11. I've got a Comanche too!
  12. I have the 2 rear XJ AVS "Smoke" guards brand new. You can have them if you need them, for the price of postage. https://www.amazon.com/dp/B0001EW03A?ref_=ppx_hzod_title_mob_b_fed_asin_title_0_0
  13. Same. I went zero to hero with that car. When I bought it I didnt even know what a torque converter was. A few years later I was manual swapping it. That really raised the fun factor. I'm glad it rotted out before I got into any real trouble
  14. In high school I learned to drive in my moms toyota sienna, and to drive stick in my dads corolla. Immediately after I bought a clapped out old bmw e30 as my first car, and I had a lot of fun with that thing.
