3041 profile views
70barracuda's Achievements
Comanche Addict (5/11)
Parking brake pedal assembly and handle for sale. $150 for both or will separate $100 for pedal and $50 for the pull handle. Located in NJ or will ship on buyers time. Handle is in great shape. No frayed wires. Pedal assembly is in pretty good shape. Actuates fine and holds. Pedal is in decent shape.
I didnt take too many pictures but I was following some else who had done it. Let me download those pictures and ill send them over.
Been researching the newer 4.3 and there's just not a ton of info out about it. Apparently they came manual from the factory in Mexico but parts are next to impossible to find. And no one really makes an easy swap harness for it. I'm trying to make this a fairly easy and quick swap. The comanche is really my "let's try this" vehicle. I want the cherokee to be super basic and as easy as a swap as possible. I think I've come to terms with an LS, has to be an all aluminum though. unless a really good deal on a small block happens. Trying to pick up an nv3500 as I can save money on no adapter needed for the ax15.
I had thought about doing the original 4.3 swap as my cherokee is an 86 and has the different engine bay dimensions. But so much research led to me to its v6 power with v8 economy so really no point. My goal with thing is a super reliable daily, A/C, easy driving and great mileage. The newer 4.3 seems like it would be a great swap and the aftermarket is slightly there. Just have to make sure itll work with my ax15 or even a nv3500.
Now that would actually be a perfect swap. I have to research that alot more.
I would probably run holley sniper on the 350. But yeah, I know the LS makes the most sense. Its just I've already done it and want something a little different. As different as I can be with a 350 haha. Either swap is going to be pretty easy.
So I cannot take my 2.5 in the cherokee anymore. It is so abysmally slow and here in NJ is honestly dangerous. So ill be swapping in a v8. This one's going to be super basic, nothing like my comanche. Question is what to put in it. My brain says LS for obvious reasons but my heart says a good ol 350. Transmission will be a ax15 so itll work with either. This thing is super clean so I don't want to hack or cut up really anything. And I just feel like a 350 fits this jeep better than a LS. Opinions? If it do go 350 itll be the last years of it, the roller cam vortec. LS will be a 4.8 or 5.3.
So it seems these pressure switches for the 2.5 power steering are just non existent anymore. Mines blowing fluid out the connector so its totally done. Would like to find a replacement but there is nothing out there. Anyone have a workaround or am I just going to have the plug it?
I would appreciate it. I know we've talked before about this thing but still can't find much info. Just going to leave it unplugged for the time being.
So trying to get my A/C going on my 86 cherokee. Alot of oddities for only the 86 which makes it fun. After replacing everything and charging the A/C i still couldn't get the compressor to turn on. Narrowed it down to this relay which I found is an anti-deiseling relay. There are 5 connections. 2 are together and 3 are together. The 2 connections are power and ground and the 3 are A/C relay power and then 2 other power wires. With the 2 pin connector installed, the relay removes power from the A/C relay. With the 2 pin connector removed, the relay is de-energized and allows power to the A/C relay and everything functions normal. I have 2 relays and both do the same thing so not the issue. The only thing I can think of is that something is telling the relay to enegerize when it shouldn't, but can't find where the 2 pin connector gets power from. Anyone have a 86 specific schematic or any info? Thanks.
Still looking for a set of the metal in channel.
Ill take them. Rather have the front atleast then nothing at all
Can't find them anywhere
