pizzaman09
    McKean Township Pennsylvania
  • Interests
    Unique engine projects. Anyone that builds truly unique engine parts gets my appreciation.
    I am big into autocross racing with a particular love of BMW e36 M3s.
pizzaman09's Achievements
MJ Junkie
MJ Junkie (6/11)
  1. I'm real close to Ohio, I live just south of Erie, PA. I have a couple friends in the Cleveland area so I make my way there every once in a while. I too will put the Comanche away the day the salt trucks come out.
  2. This is an awesome little truck. I'm personally a fan of the stock graphics but it also looks great without them. I fixed that throttle cable issue on my truck with a zip tie in the same location clamped into the cable.
  3. I really like this truck, fantastic look with it lowered and the white letter tires complete it.
  4. My suggestion isn't based on experience but you might check the conncections at the ECU, unplug it, contact cleaner and plug it back in.
  5. I'll be curious if this actually reduces noise for you.
  6. This actually is very wise advice. Even better of you take that $1000 and invest it in a CD.
  7. I've never seen one with under hood insulation but it can't hurt to try that product. My understanding is the Comanche and Cherokee hoods are identical other than early ones had a single latch instead of the double on the later ones.
  8. I like the idea, though I think a swap to a 4:1 transfer case would provide the same benefits to me. Even when I'm towing a heavy load on the road, the factory first gear is plenty low enough. It would be epic for crawling.
  9. Samurais are fun! I have a friend with a 1988.5 model, it is one of the most fun ways to zip around town or go to the beach with some friends. It's also the most capable vehicle I've ever driven in the snow, 4x4 in a light weight truck with no power and good snow tires.
  10. Working on mounting up the DC drive motors. Also have all of the batteries built up and have them running a portion of the house off grid with the inverter that will also be used to charge the batteries when they are used for the blower.
  11. I know you have a 2.5L and my experience is with the 4.0L engines but I suspect this applies. I've had issues that cause this sort of bucking caused by exhaust leaks from the exhaust manifold before the O2 sensor. Check to see that the intake/exhaust manifold bolts at the head are tight and all present. If not it can be leaking and you might even have a bad gasket there. You could also have a crack in the exhaust or even a bad O2 sensor. The symptoms change as the exhaust system heats and cools along with thermal expansion.
  12. I went with the Key Parts ones. I would advise for installation to either get 3/16" aluminum rivets or aquire a heavy duty pop rivet setting tool for the stainless ones that come with the Key Parts kit. I broke 3 pop rivet guns trying to set those stainless steel rivets before I gave up and swapped them for aluminum.
  13. The release button on my driver's seat belt no longer pops up and the latch is now unreliable. Does anyone have a driver's seat belt latch (female end with the release button).
  14. I did this with my factory one when I had my transmission out! Definitely easy to do if you have it out.
