ghetdjc320
    Arkansas
  • Interests
    Semper Paratus 🫡
ghetdjc320's Achievements
Obsessive Comanche Disorder
Obsessive Comanche Disorder (9/11)
  1. Good point, it very well might. Brake light switch is the better bet then. My painless harness came with a 3rd brake light wire so I just used it but not sure where the factory wired it into.
  2. You could tap into the brake light signal where the harness goes through the floor under the drivers seat. Then just run up the b pillar. Also a good time to add a cargo light wire if the truck didn’t come with one originally
  3. I used the Morimoto F-250 third brake light with integrated cargo lamp. But you’ll need to cut a slot.
  4. For some context, I was just going to order up a Fusion or Currie JK44 which already have TJ brackets on them. It looks like both units simply have a track bar bracket with multiple holes. Regarding the D30, a high pinion non disconnect Dana 30 is a solid little axle that works surprisingly well on up to about 35’s. And as for a drop pitman, I don’t have any leverage issues against the uniframe to be concerned with on my particular build but I’m thinking that at 3.5” lift and with the drag link already mounting a bit higher than the stock D30 location, I probably don’t need to make it any more parallel to the ground than it already is. I guess the geometry may be similar to a WJ knuckle swap with stock draglink location. But as far as I know, even those swaps all require moving the track bar above the axle.
  5. For any that have done a jk front 44 swap, I’m curious to know what you did for the track bar. I’m wanting to keep stock style JK steering design with the dragline under the steering arm (no high steer) and keep my 3.5” lift. Most track bar setups I see for this swap are for high steer
  6. Just to put this out there as it frequently gets missed: Truck Covers USA makes what I’d call the best bed cover specific for our trucks. It’s about 2k, and a top quality unit.
  7. Well, I got the new cluster installed and working properly. Can’t say enough about how much I like this cluster and how well Dakota Digital did on that build. It’s just a beautiful piece of quality workmanship. On a second point, I finished the audio install with the Morel Integra speakers, pair of JL b pillar subs, the custom RX173 head unit with DSP and the JL 3 channel amp. All I can say is wow. This is how the audio should have been built. It is completely stealth with zero interior space used at all and the sound quality and power is amazing. Easily beats out a pair of 8-10 average subs while taking up no space. And the integra speakers have a nice wide soundstage that fits the cab. Will button up the interior and get some pics taken.
  8. We did a pretty deep dive into these radios in two of the DIY section threads. “what Minuit knows about stock Jeep radios”, and “What CC knows about stock Jeep radios”. Lots of general information along with some very technical info for those looking to mod their radio.
  9. I’ve used the open end wrench method then tack welded it into place.
  10. Under the hood, your mostly looking to add a heat barrier and some sound absorptions doesn’t hurt. For that purpose, the factory fiberglass liner was great. It could be slightly improved upon but most aftermarket products will take a lot of work to fit all the contours and provide the same level of coverage. So even though there may be a superior product, I don’t believe you will necessarily get superior coverage.
  11. There are a variety of dryers available some with the port and some without. Vintage air or jeep air both carry a simple inline T adapter for your sensor. You just need to verify what the thread size is. The lower condenser-to-dryer hose is a high pressure line. Possibly called the “discharge” line.
  12. 4.56 gears would be my vote. I run 4.56 with metric 33’s that run almost a perfect actual 33” diameter.
  13. Once you go LS, you won’t go back
  14. Well, I guess just to add to the conversation, after having built many a 4.0 and stroker variations thereof, an LS swap is my go to and I don’t look back. That being said, the best bang for buck was a stock 4.0 bored .060, with an edelbrock head, decked down for an .038 quench and about 10.75:1 compression ratio. That engine build was a few grand but less than my other strokers. With 4.56, my aw4 and 33’s, It performed admirably. But still no where close to a true LS swap. I’d like to try forced induction as well on a 4.0 as it would be a good candidate. But ultimately, it’s a tractor engine with a terribly outdated design. I don’t mean to disparage it to much but realistically, you don’t really notice an extra 40hp on a 4.0 given the power band. And you can sink a ton of money into them with very little to show for it. Even at 300hp, still feels like an anemic boat anchor. Forced induction, gears, or an engine swap would be my go to. And gears would by far be the most cost effective of the three.
