robfg67
    Walpole, MA
  • Interests
    Family, Comanche, Pinball
robfg67's Achievements
MJ Junkie
MJ Junkie (6/11)
  1. One of the weirdest Craigslist posts I have seen in a long time, but good luck.
  2. Not a bad price . Good luck getting the factory plug out of the engine.
  3. I have one available, but I'm in Massachusetts.
  4. Derf, yeah, I'm sure there has been fading over the years. What I'm asking is, if different interior colors over the years apply to the dash, the trim only, or both.
  5. I also have a '92 MJ with the "Dark Sand" interior color. Boy, the color of the '92 dash board looks like the earlier model colors "Tan" or "Sand" to me. Did the "Dark Sand" color only apply to the plastic interior trim pieces and not the dash board? Thanks
  6. Sorry for the delay on this. I've had my hands full with another Jeep that I picked up recently. I couldn't find any issues with the lines at the top of tank. My plan is to slightly overfill it and look again.
  7. Any ideas on what to check for? As stated, it only smells when tank is filled. There are no leaks/drips. No smell at all when tank is below full.
  8. I like it! You've got other chrome in the windshield moulding and front bumper to tie it all together.
  9. Crap, sorry about that. I forgot that I posted it to the registry already.
  10. Here are the pictures from the parts catalog that detail the 10/4/88 difference:
  11. Thanks for all the responses. I just added the VIN to the registry. The 87-90 Parts Catalog that I have in digital form lists on page 584 that the AX5 was changed on 10/4/88 and has two different part numbers for the transmission: Pre 10/4/88: 5300 3024 Post 10/4/88: 5300 6169
  12. I have a 1988 MJ with the 2.5L, the 5-Speed Manual AX5, and it is 2WD. From looking through the factory parts manual, it appears that the AX5 transmission for my application changed on 10/4/88 and I'm not sure of the build date of this Jeep. This transmission was used on all MJ's and XJ's from 87-90, but there are two different ones used. Questions: 1. Would it matter which version I sourced? Are they interchangeable? How can you tell what the differences are? 2. My '88 is 2WD. Does it matter if I get a replacement one that was mated to a transfer case? Thanks
  13. No response, so I ordered from Kody in Maine.
  14. Hey, I'm missing a couple of parts to my charcoal gray bench seat. I need the following: Driver side hinge frame trim cover The oval shaped plastic seat trim that the female side of the seat belt fits through. I only need one, but I'll buy both if you don't want to split a pair. Thanks
