ComancheX2
Location
Kansas
ComancheX2's Achievements
Sounds like a really good opportunity. I've tried to find some of the night/vo-tech classes for welding and such around here, but they don't offer anything other than full curriculum options. Can't offer much other than sharing my accounting professor's theory on the three levels of economics: First you have frugal. Below that you have cheap. Then below that you have stupid. I try and stay out of the lower two categories, not sure if I always succeed though!
Thanks Eagle, I wasn't sure if it had been changed over yet. I think it will be convenient to change it over for commonality being that I have an XJ too, but for the moment, I'll get a metric filter to get it going. I've got several things I want to do and it would probably be smart to get them done first before winter sets in. 1) reconnect the parking brake the PO didn't hook back up after they installed the lift. 2) replace any wear components needed in the suspension steering systems 3) do a brake job
Thanks Ilhat, sound like you may have the same luck as I do! ;) Pete, the rubber glove is a good idea! I did a search for the type Fiat posted. I couldn't find the same one, but did find a Lisle 63250 in stock at one of the three autoparts stores and ran in and grabbed it. It sure was tight, but finally managed to break it loose. Now that the filter is off, it does have metric threads. I had a couple of the filters from my XJ I was thinking I'd use, but I'll have to make another trip into town to find the correct one.
Thanks a bunch! I haven't seen that type before. Does the adjusting the nut on the end draw the jaws in tight?
ComancheX2 started following Oil Filter
I started to do my first oil change on my new to me MJ. I'm having a heck of a time trying to get to where I can position the wrench and get any movement. The cap type wrench didn't want to stay on, so I got a chain type and between the engine mount, the distributor, and the evaporator canister I can't get to where I have enough movement. Anyone have any tips & tricks they'd be willing to share? My '94 XJ has the filter horizontally I'd reach up from underneath and never had any issues with it.
Ah, no 121 for me, but I worked on a few DoD systems as well. So I share the proud of what I worked on.
Sorry if I hijacked this thread! And Derf, sounds like you worked on 121 category aircraft? I got into aviation flying with my Dad as well. I soloed at 16, (I was at the World Boy Scout Jamboree on my birthday so I had to wait until I got back to solo) and got my private at 17. Took my instrument checkride with a dual Nav, single glideslope, and ADF. (And with the ADF you could still listen to the ball games enroute!) Much different than today's 'children of the blue line'. Somewhat of a tangent being we're talking IFR here, but the last private student I had was fixated on looking inside to determine the attitude of the aircraft. After trying a couple other things, eventually I had to take a towel to completely cover the panel and say 'pitch the airplane to Best Rate of Climb and tell me when you think you're there'. A couple of times doing that brought some balance into his scan. But to keep it MJ related, the PA-30 is similar. Not the best at one specific thing, but good at most things. The Ford Lightning is faster (Barron), the F-250/2500 will haul more (Aztec), but the MJ (PA-30) is very useful and good at just about anything. My Twin Comanche was almost as fast and could haul 4 people and luggage while still having 6 hours worth of fuel at 15 gallons per hour.
Didn't sell it. Long story, I'll just say Garmin, their dealers, & A&P's aren't what they used to be.
Another (former) Twinkie owner...
Yeah, good times with my grandpa, my dog, & my Jeep! Nice action shot fiatslug!
Does it have to be an MJ? Will an XJ work since it's the MJ's 'half breed cousin'? :) This was my blonde haired, blue eyed badger hound who went almost everywhere with me in my Jeep. One particular memory was when I was taking my grandfather out on his farm when he was 96 or 97. She treed a pack rat and he got such a kick out of her, he wanted me to cut down the tree so she could get it. I'm wanting to get another best friend, so maybe now that I have an MJ I can update this next spring.
New carpet in as I redo the interior.
ComancheX2 replied to OzarkGuy's topic in MJ Tech: Modification and Repairs
That looks nice! I have to say I prefer the pre-97 center console that you used as compared to the 97+ the prior owner(s) used for mine. For me, it just looks right. But then again my first vehicle was an HO era XJ. So I'm probably biased! -
Modified OEM Radios “Feeler”
ComancheX2 replied to ghetdjc320's topic in MJ Tech: Modification and Repairs
I'd be interested as well. After seeing this, I was just reading your other thread. It's all Greek to me, but I may even have an old unit that could be refurbished if I can manage to clean out the garage! -
Yep, both stock HO era 4x4's, so the HO may definitely be a factor. If they like a little more RPM's then that does make sense as it was doing about 1600 or so at 60 mph. I know my IO-320s liked to be at 2400 RPM, but that's a different beast. At the moment I'm driving about 115 miles per day. So with 17 mpg and $3.69+ fuel it's creating a little more of a hit than I expected. Looking for a decent FWD KL for the daily drive until I can get out of that situation. While talking to a co-worker, he told me about "Kansas Rocks" and said he wanted to take his kids sometime. I'll likely go along with him sometime before deciding if I want to keep the lift long term. Right now I don't plan on doing a bunch of rock crawling, so not totally necessary for me.
