Pete M
Administrators
    114
About Pete M
    Detroit or Atlanta
  • Interests
    Anything in the great outdoors!
Pete M's Achievements
down with the MJ sickness
down with the MJ sickness (11/11)
  1. most all the welding is going to be simple spots and rosettes. the factory doesn't have a lot of long welds anywhere so there's no need to get carried away. I'm replacing both floors and bought a flange tool to mate them with rosettes rather than butt welds. the thinness and awkward angles are the real challenges. practice on similar metal. and practice in similar positions you're going to find on the truck. practice, practice, practice.
  2. I mean, I clean my mower with the garden hose and an old mop, so... I own a westinghouse electric that does 2300 psi. it's ok for regular jobs. I would not use it for big jobs like a house or driveway. takes too long. but on the plus side it fits in a rubber maid tote so it's easy for me to transport to other peoples' houses inside the car.
  3. one time I had a filter that didn't quite fit the cap wrench and got it to work by putting a couple rubber gloves between the 2 for grip.
  4. if this is for occasional use, you can simply rent a gas one no need to store it or fix it.
  5. if you can, plan on stripping EVERYTHING out of the cab. the firewall will have more problem areas and the only way to get at them is with the dash out. you must find all the water leaks now, or it'll all go bad again later on when it gets wet again.
  6. that people tend to forget that we exist. lol
  7. 1000 buys a lot of oil. as long as you can stay ahead of it, it can leak for decades and you'll be ahead of the game. My PT Cruiser leaks oil, antifreeze and r-134. eventually I'll fix it all, but I'm in no hurry because I simply keep it topped off each week
  8. now why would you go and do a thing like that?
  9. all it takes is rain. that's why floorboard issues are so common.
  10. new sockets are available. I would get a hold of the wiring diagram and start from scratch with proper connections and shrinkwrap. heck, I've even replaced the bid connection under the truck with new. the old stuff just kinda sucks. I prefer the low-temp solder connections (which has its own heat shrink) and put a layer of regular heat shrink over top of it for durability.
  11. wrestled the rollbar out today. only snapped 2 bolts (so far. the frame reinforcement brackets still need to be addressed)
