neohic
Moderators
    2
Everything posted by neohic
  1. Beautiful truck!
  2. Welcome aboard! Such a rad truck.
  3. The suspension has been settling in just fine with that big ol’ top on it. Today’s project though was to swap out the spark plugs and diagnose the fuel gauge issue. The spark plugs looked okay(ish) but I also haven’t looked at them since the engine went in and lately it has been stumbling a little at startup. As for the fuel gauge, I thought about adding an inspection hole while I had the tank out, so I went ahead and added one. … almost in the right spot too! Unfortunately, the sweep mechanism is totally broken. Bummer.
  4. The rear diff cover started leaking so it got replaced today. Paint it black. Hit the track.
  5. Tough to read, but it still exists.
  6. MJ with an MJ: Up next is your truck at the car wash or getting washed:
  7. Welp… today is that time of year again to put the top back on. Unfortunately, I need to drop the new fuel tank due to the fuel gauge not working. That’ll be another day. I was a bit worried how the heavy top would settle on the new suspension, but so far so good.
  8. I’m assuming it was something from inside a fuel hose? When I took the filter housing apart, the icky black stuff was like a furry residue… I guess? Weird.
  9. Damn CJ left me stranded!… blocks from home. It had the same feel in the throttle like it was out of fuel that it’d idle but die when given any gas. So?… … glad I added a pre filter! There’s a 10 micron filter after the pump and I put in a 100 micron filter before that I could keep an eye on. Guess I should’ve gotten the three pack of filter elements at the same time! Not saying I’d be pleased if it decided to clog up two more filters right away, but theres backup elements in the console now.
  10. You know that fancy, new bed I just finished? You know that thing where you slightly rearrange your furniture and bad things happen? Yup… that happened.
  11. Back on the road and into its usual parking spot! I was worried that space would get tight under the floor but there’s plenty of room.
  12. I love how four door classics are finally getting embraced. Well done!
  13. At least 4.56s. I don’t put freeway speeds into the equation unless it’s a vehicle that primarily sees them. Getting to and from the destination in a modified vehicle is absolutely part of the journey.
  14. Literally a day late. I wanted to get the CJ out of the shop yesterday but I just received the replacement tank. Honestly, ordering a fuel tank feels a bit out of character for me that I feel like I typically would’ve made a new one out of scraps or found materials. My material stash just isn’t what it used to be! Anyhow… I should be working on it but I went and broke my toe this morning.
  15. Looking great so far!
  16. ^This also. I love my stroker as a 6 cylinder. I’d never build one ever again though.
  17. ^This. Even after building a mild stroker, I’d never do more than a quick rebuild on a 4.0 again. The power is nice, but after moving from MN to the higher altitude on CO it just feels more like a brand new 4.0.
  18. There is a drywall screw, a self tapping, machine screw, and a steel siding screw with the rubber washer for extra sealing strength.
  19. Ugh… So there I was trying to better the Jeep by making an actual fuel return and slosh pan to get to the bottom of the fuel issues. I get on to cleaning out the fuel tank and I found not one, but FOUR SCREWS plugging holes and some hardened peanut butter looking junk slathered over a bunch of rust. Not just four screws, but not even the SAME four screws!! I briefly debated patching the tank, but the more I cleaned the worse it got. Ah well… new tank is on order. I moved forward with using it to mock up the new pickup, return, and slosh pan. My material scraps are REALLY getting down there! A new gasket is also on order, but I borrowed it and the split ring from my auxiliary fuel tank from the Moab trip. The slosh pan sits on the bottom of the tank and has the return dump right into it while the new pickup location is towards the back. This should keep the pickup submerged all the time. I’m set should I decide to go with an in tank pump in the future. Now the old fuel pickup and gauge sender is just a sender. The old pickup got cut off and will now just be a vent. I would imagine it might’ve had something to do with the issues, but the pickup screen was falling apart and could barely be seen through. … and now we wait for parts to show up.
