1805 profile views
Boilermaker's Achievements
Comanche Aficionado (4/11)
Pry it with a screwdriver https://www.cherokeeforum.com/f2/fuel-cap-stuck-my-91-cherokee-148867/ Pressure may have built up inside the tank and up the fuel filler neck pressing on the cap. If you can remove a hose to the tank or the filler neck to relieve the pressure, that may help loosen the cap.
I think all of the sealer from the factory is 1k which often shrinks as it dries. Probably more so where its applied the thickest, like the front of the floor pans and back of the interior cab. So what was likely done to protect the metal from the worst areas of water penetration may have made things worse in the long run.
No problem. As the others have said, seam seal everything. Only one other thing to add, and from your pics looks like you may have already done this - remove all the factory seam sealer you can. When I had my truck cleaned up, most of the spots that needed attention were under the factory seal sealer.
Seam sealing locations from MR278. 1571325217_MR278R11-22.pdf
Boilermaker changed their profile photo
7 5/8" measured from the very end with steering knuckles off. Both my C's were within an 1/8". Gears were recently replaced professionally, so it should be straight. Can measure in a different location with knuckles still on. With all the brackets on the axle, couldnt find a good way to measure the angle. Couldn't get an accurate measurement while holding the phone, so the Pic is more to show where I measured.
My floors were in decent shape so I only had my floor supports replaced. The shop that did it drilled out all the spot welds to remove the supports. The OEM supports probably could have been reused. He cleaned up any surface rust under the supports and where the factory seam sealer was prior its removal. Then put down a layer of 2k epoxy primer, 3M 2k seam sealer in the factory locations and another coat or two of 2k epoxy primer. It's a lot of steps, but since I don't have any welding skills it's something I didn't want to have to address again.
If you're planning on doing some welding anyway and the parts aren't cost prohibitive, I suggest using the Key Parts floor pans and supports. The Key Parts panels i've used have been good and the time saved over piecing together patches can be spent on other fixes. There is likely more rust you can't see under the floor supports and factory seam sealer. You'll be able to get at more potential problem areas with the floors removed. The welding doesn't have to be visually perfect since it should eventually be covered in seam sealer anyway (plus any sound deadening, carpet, etc.) Good luck with the repairs and welcome to the forum.
Roof Flex (oil canning?)
Boilermaker replied to Boilermaker's topic in MJ Tech: Modification and Repairs
Thanks for all the responses. The dynaplate is an interesting idea. The plan for inside of the cab is to spray a few layers of lizard skin sound and thermal directly over 2k epoxy. Adding dynaplate to the roof, either above or below the lizard skin is a good option I wasn't previously aware of. Since that amout of flex isnt unusual, I think I'm going to pass on doing anything mechanical like shrinking. Not worth taking the chance of creating a larger problem. -
My MJ has been stripped of paint and is currently in primer. Shop is concerned about the amount of flex in roof. No signs of any previous damage. I know the roof is pretty thin and has some give to it, but is this too much? Thanks in advance roof.mp4 roof.mp4
Comanche Headliners on Sale
Boilermaker replied to a1500ram's topic in Vendors- members making products for MJs
Steve has been great to work with. Mine will be arriving next week and am looking forward to it -
This. We are switching to Hagerty because we can't get our current insurer to look beyond KBB value. Wouldn't take much damage to exceed our "agreed" value.
LowerEnder started following Boilermaker
No problem. It may be possible to go slightly longer, maybe 5/16" or 3/8" (Arrow 505 or 506) for a better grip without going thru the front side of the skin. 1/2" is definitely too long, i remember starting with that and having it poke all the way thru. I've have two more door skins in my parts pile that i haven't gotten around to doing this on. Would be a good time to try a couple of different things and post a write up to the DIY section.
