A-man930
    3
    St. Louis
  • Interests
    Wrenching. Eating. Sleeping.
4013 profile views
A-man930's Achievements
MJ Junkie
MJ Junkie (6/11)
  1. All the rust repair on the MJ has prepared me for this:
  2. All 16 lifters disassembled, cleaned, and put back together. This is routine maintenance, right?
  3. Yeah, as home-brew / cheaply as possible. It had 3 stuck intake valves.
  4. Olds 330 with a 2bbl and an ST300 behind it, sir! Slowly working towards getting it to run.
  5. Well, the 4dr price point helped make my decision
  6. Between the slow pacing of my MJ restoration, mild ADD, and my kids bugging me to get a hot rod... I did a thing.
  7. If there's access, go with a 2k epoxy wherever possible. Cavity wax through a diffuser tip for areas you can't get at AND periodically/seasonally after that.
  8. If you don't already have one, get an electric file belt. It'll make the grinding less annoying.
  9. I love it. Sorry if you've mentioned it already, but what is the supercharger you're going with?
  10. Strange... Maybe S10 then? I could be remembering wrong... Anyway, there's plenty of Jeeps around that could use it. Just throwing it out there.
  11. I think this is a common device used in any make/model with a Saginaw column. GM trucks, for instance.
  12. Love it. Have you reached any other "markets" for these?
