A-man930
    3
Everything posted by A-man930
  1. All the rust repair on the MJ has prepared me for this:
  2. All 16 lifters disassembled, cleaned, and put back together. This is routine maintenance, right?
  3. Yeah, as home-brew / cheaply as possible. It had 3 stuck intake valves.
  4. Olds 330 with a 2bbl and an ST300 behind it, sir! Slowly working towards getting it to run.
  5. Well, the 4dr price point helped make my decision
  6. Between the slow pacing of my MJ restoration, mild ADD, and my kids bugging me to get a hot rod... I did a thing.
  7. If there's access, go with a 2k epoxy wherever possible. Cavity wax through a diffuser tip for areas you can't get at AND periodically/seasonally after that.
  8. If you don't already have one, get an electric file belt. It'll make the grinding less annoying.
  9. I love it. Sorry if you've mentioned it already, but what is the supercharger you're going with?
  10. Strange... Maybe S10 then? I could be remembering wrong... Anyway, there's plenty of Jeeps around that could use it. Just throwing it out there.
  11. I think this is a common device used in any make/model with a Saginaw column. GM trucks, for instance.
  12. Love it. Have you reached any other "markets" for these?
  13. Fixing > replacing. Good work. Where did you get your rebuild kit?
  14. I followed in the footsteps and inspiration of others. I haven't driven it yet, and I don't have the correct length stick on it, so I can't truly say if I'm satisfied or not. If I were to do it again, I would be less conservative with the length added. Noting that this Novak piece is a full inch longer, I bet it's pretty great. Edit: here is the thread. https://comancheclub.com/topic/74091-ax15-short-throw-shifters/#findComment-775573
  15. Donor doors from an '88 MJ. Getting 1pc power glass and late model mirrors. ... all work I've been dreading for years now
  16. Modifying window tracks... very exciting.
  17. Something like this? https://www.amazon.com/Rosco-Roscolux-Scarlet-Gel-Filter/dp/B00BAXU4TS
  18. Yes, would definitely need the LCD to match the rest of the backlighting.
  19. That's relatively easy then. Cool! I've always wanted red backlight in the MJ just like my old Firebird.
  20. I guess this blue filter is in the panel face vs a boot/condom over the bulb?
