2
ThatJeepGuy's Achievements
Comanche Aficionado (4/11)
Suzuki samurai folks here?
ThatJeepGuy replied to ThatJeepGuy's topic in Member Projects: Other Cool Stuff
Decisions were made... Body progress is slow but things are progressing. Ive decided on utilizing the axles I'm swapping out from my jk (d30,d44) for this build. They are without issues and Free! This sets up easily for the next decision, it would simplify things if I just default to a factory frame vs building one from scratch. I'm adamant - not using this samurai frame! Soo why not just get ahold of a jk frame, utilizse all the stock suspension parts and just get creative with body and drivetrain mounting? For a mere $400 it was a done deal! More to come on this, my garage is a disaster atm -
I've had a couple gas units and been happy with them but with the cost of fuel and the maintenance on them for seasonal use I gave an electric unit a try. 6-7 years later our ryobi unit from home depot still does the job! Psi not accurate to my machine but thats the essential unit.
Yes pretty much, an offroad utility vehicle, with a small hoist crane mounted or mountable to the bed for lifting heavy awkward items... ran out of free time before I could nitpic more on detailed items -
(JT RUBICON FOX SHOCKS) Used them on an XJ project of mine a few years back. Its simple to drill out the center bushings and incorporate the correct metal bushing to get back to the MJ hardware. Page 5 here: https://www.cherokeeforum.com/f46/98-cherokee-very-basic-capable-dd-221342/index5/ I do believe there is technical data on the shocks being set at the same ride height measurement as the JTs for proper design performance (valving performance through its travel) but they were fine from my experience
Messing with Ai renderings... Not soo much the tube work or visible fuel cell, though its don't mind the idea of the Apillar tube and working back from there for a potential hybrid cage setup. -
Progress! Addressed the caved rocker panel Just as i had thought - the B pillar and door alignment were easily corrected after fixing the caved section. Door latches were sticky but got them freed up enough to open and close the doors and with those doors finally latched closed - i got started with mating the tail section of samurai body to the main portion to begin the truck cab part of this project. No close ups of my $hitty welds as this samurai metal is thinner than the XJ/MJ work I'm used to. Plan is to seam the sections together (best i can) then rear qtr armor the outsides to aid tieing the sections together and for the esthetics More to come! -
Covered until nov 20th Code: 356205666313426950
Just a little progress over the weekend. Doors arent latching just yet but i did tickle the body some more for a closer visual tease of the back of cab setup. -
Is this an old suspension lift?
ThatJeepGuy replied to emosun's topic in MJ Tech: Modification and Repairs
This... and those secondary spring clamps... the end of that AAL doesnt look very tapered like most ive seen, also doesnt space out like it maybe should. Id be curious if the AAL itself is a cut down leaf from another pack? -
Samurai parts pile... A member on another forum local to me shared a pile of samurai leftovers... The main grab here was a frame, doors, hood and windshield frame. Only amazons finest hockey pucks gets used for body mounts in this driveway. My current task is utilizing the frame with the body bolted down to get the body back into square for the doors and top to fit right. I'll also use this time with the frame attached to start aligning and welding in the rear of this to make it a cab. -
Agree on the regear. I had 36 iroks and 4.56 many moons ago as my DD and it was manageable but wanted the 4.88s.
I have a few if you're interested.
mini beast Project: Stock To Beast!!!
ThatJeepGuy replied to MiNi Beast's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Nice to see some movement here! -
1987 Comanche The Long Hard Road
ThatJeepGuy replied to ThatJeepGuy's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Subtle prep work has begun for a return trip to windrock. Earlier this summer we made the annual jeep blessing here in Michigan... jeep got tired and took a nap Zero actual damage, co pilot was a little uneasy but came out with a smile 😃 Today's to-do list was a new clutch fan, new alternator and some how to teaching with the younger kiddo. Serpentine belt ia tight! Steering box replacement, total fluid check and then potentially a revamp of the rear tube work to accommodate storage space and revamp of the rear shackle mounts tomorrow... -
Was not hard at all on this one, even did it in my "nice clothes" at the end of the night after putting kiddos to bed. Wife gave me a look while I was looking at it in the garage putting some stuff away. "what ya thinking?" Me? - firing up the plasma cutter and ditching this rear section... "soo what are you waiting for?" Yea i suppose it won't take long soo why not. My next trick will be figuring out how to un-frowny face the body to get the door strikers to actually line up with the door latches...
