Tj1
1 Follower
    Grand Rapids MI
1472 profile views
Tj1's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. I recently bought a Cherokee for a daily and the audio get to quiet when at a stop or braking. The deck is aftermarket and has a sub/amp combo. Any ideas on how to stop the spectre? Sent from my SM-G892U using Tapatalk
  2. Interiors is gone and ready to clean th engine bay and start pulling the xj stuff Sent from my SM-G892U using Tapatalk
  3. Dash and wiring is out. HVAC stuff out next! Sent from my SM-G892U using Tapatalk
  4. I'm dumb. I had the bench seat out while doing the floor pans and used the top of the back rest. I would like to one day make a bolt in application for my Comanche Club friends, so I would set up a jig to form the next batch Sent from my SM-G892U using Tapatalk
  5. 4" cutoff wheel and being gentle. Making cuts every 1/16" or so and twisting the grinder to remove the metal strips. Then clean up rough edges with a rounded file.... Took forever Now that I have access to a cnc plasma table it's like 2 hours of work versus 2 mins Sent from my SM-G892U using Tapatalk
  6. Thanks!! Sent from my SM-G892U using Tapatalk
  7. How the heck does this unplug from the firewall? I'm driving the struggle bus for longer than I want.... Started doing the 97+ swap and most of the dash is out but the wires are stumping me. Sent from my SM-G892U using Tapatalk
  8. Tj1
    An actual crew cab
    Just seen this come across my news feed. Impressive build!
  9. I didn't want to spend the 200 and built my own for the cost of steel Sent from my SM-G892U using Tapatalk
  10. When I did one in my TJ this video helped so much Sent from my SM-G892U using Tapatalk
  11. I went to Tractor Supply and bought a 110 welder just for my keeps. Necessary item if you own a jeep! Couple YouTube videos and I was off. Remember if it don't look good you can always grind or cut to try again Sent from my SM-G892U using Tapatalk
  12. Finally got that tired renix out. Next step is tearing into the dash and clean the engine bay! Sent from my SM-G892U using Tapatalk
  13. Rough fitting of the hood with the vents welded in. Touch up and then paint and the hood will be done! Sent from my SM-G892U using Tapatalk
  14. Took a break from engine stuff to burn out hood vent panels (on the work plasma table) for a cowl induction type hood. Hopefully it'll help with heat in the engine bay. Sent from my SM-G892U using Tapatalk
  15. If my rig is ready by then..... it's only a 4 hour drive for me. Defiantly interested! Sent from my SM-G892U using Tapatalk
