3
Everything posted by 88whitemanche
Oh definitely, I hated not having it after I got a functional vehicle that has a properly working a/c... so it’s gotta be in it when I get it back up running again hey bud, mill be looking to convert to a 4.0 from 93-96 so luckily I don’t have to search long and hard for remix parts
"Wendy"- 88 Jeep Comanche Build
88whitemanche replied to Swampy's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Spicy! That long arm kits looks mighty familiar lol... I can’t wait to see it getting done -
Yeah it’s been a while, bought a house and just have been using the truck for supplies for the house... here’s one when I had 100 landscaping pavers in the bed
Hello everyone, it’s been a long time coming but the one of the angry squirrels finally broke the block, I am in the mix to swap in a 4.0 from an xj. Ive just been scouring OfferUp to find a good donor to get back to really enjoying the truck... biggest part has to be a/c as the wife would really like to have that to actually enjoy the truck
Hey bud, It’s been so long since I’ve been on the forum, the first 3” coil were the rough country brand the The rest were rubicon express, no complaints with RE, the rough country ones ended up getting too soft after hard use....
Ended up being the fuel pump relay... now there’s another issue... lately I’ve been a lot of more mileage than what the truck is used to,but when I’m getting slow down to a stop I normally press the clutch and put the transmission to neutral the rpm gauge drops so low that it wants to shut off, the past 2 days it’s turned off on me twice Both times going around a bend at 70mph on the highway and I just pressed the clutch to prepare to brake as the car in front of me was slowing down... luckily I was able to start it back up again at the moment
What’s up everyone I have been having this issue with my truck when driving down the highway it will out of nowhere bog down and pick back up right away. It’s not shutting off and rpm gauge isn’t showing any signs of any immediate drops.... ive done the grounds upgrade, upgraded wires, c101 delete, etc etc.... maybe you guys can give me some insight or something that I might be missing...
Exhaust manifold bolts
88whitemanche replied to 88whitemanche's topic in MJ Tech: Modification and Repairs
ill be doing torque pattern again...but with a bit of thread locker just in case I don’t gotta worry about bolts backing out -
Nah I mean at the head, but I’ll double check sequence but I’m sure i started at the bottom middle of the headers -
Got a link for the studs? -
Just recently replaced my exhaust manifold and my truck as most of our trucks have issues if the bolts backing out what are you guys using or suggest I used so the bolts stay in place thanks in advance
it’s the only thing shiny on the truck but it’ll change colors soon lol
It’s been a while since I’ve updated, haven't really done anything except replacing front brakes as one was seizing, I just replaced the exhaust manifold this weekend as it’s been long over due and Comanche has been become my daily driver as my Cherokee 4.0 has really bad piston slap. Gasket was really bad the gasket that came with the newer style headers was off so I had to call 5 auto parts stores and 1 only had it in stock and newer manifold installed still gotta go to an exhaust shop and fix the set up past the rear routing but definitely feels/sounds different in the cab
The 2 door looks familiar wasn’t it picked up in south Florida not that long ago? Looking good nonetheless Here’s my combo 88mj /98xj
What’s up fellas have been in Colorado road tripping and saw this VERY clean pioneer
There’s another one in the same yard... pretty clean one but not 4x4 though
Figured since I own an MJ I should say hi
88whitemanche replied to DrMoab's topic in Member Projects: Your Comanches
Wow, always have had a thing for a white Comanche got more details on drivetrain, suspension, and that tent set up? -
What about the 2.5L with an ax15/nv3550 combo?
Hot hot hot! Comanche crank no start
This is the spare... -
I’ll check my spare tb and get pics for you guys... jeep driver if you got part #s on the parts you used that would be great... ive done hornbrods fuel pressure gauge on my 98xj but never knew it could be done on the 2.5s -
How did you get this to work? I don’t recall a nipple on the tb -
I don’t think the 2.5 has a spot to check fuel pressure...
