3
Everything posted by 88whitemanche
Hot hot hot! Comanche crank no start
88whitemanche replied to 88whitemanche's topic in MJ Tech: Modification and Repairs
Ah ok, had reused the strainer from the previous pump... this pump is definitely bigger than the previous one.... but truck fired right up after I primed it and it’s been running good the last 15mins no issues -
Do you happen to have a strainer on yours? If you do, have the part #? -
Yes it does but no strainer for some reason... -
Ordered same part # through amazon prime... thanks bud -
1157 and 1156 light sockets source
88whitemanche replied to WolverineCub's topic in MJ Tech: Modification and Repairs
Amazon has a set of 2 for under $10 -
I see rockauto has the carter pump set that mentions having an actual or Bosch pump...should I get that one instead? -
Just an update... its the fuel pump... swapped in a new airtex one about 2 years and I guess it died.... used starter spray and it cranked right up then died, tried again with starter spray and started up and died again... going to order a Delphi brand one tomorrow -
C101 connector was deleted and I’ll check the output today when I get back from work... -
Yes, I was able to move the truck back home i had flat towed it with the Cherokee I’ll get to messing with it today if it doesn’t rain... gotta double check the resistance on the cps, Gotta see if I’m really getting spark -
Yes I did... -
Good morning fellas got an issue right now where my truck doesn’t start...it cranks but doesn’t start... i changed out the crank shaft position sensor and no luck.... checked battery cables (clean and tight) checked started wires (clean and tight) checked starter relay wires (clean and tight) unplugged connectors and all are clean and tight can’t check spark without of help of someone with me I’m at a plaza parking lot and can’t get to work without it.... any other ways I can try it out?
These are commonly used https://www.quadratec.com/products/24226_X0X0_PG.htm And a write up https://www.naxja.org/forum/showthread.php?t=946575
Hmmm....
Yeah spider gears are all the same
Bored throttle bodies
88whitemanche replied to MeanLemons's topic in Vendors- members making products for MJs
I don’t think they are the same... i have a spare tbi one if you want to try it out... just gotta find the time to ship it out -
62mm and 88 -
Krustyballer Fabrications
88whitemanche replied to shelbyluvv's topic in Vendors- members making products for MJs
Any luck from this happening yet gas tank skid plates....- 197 replies
- hitch
- hitch plates
(and 10 more)
Tagged with:
I just saw this.... I’m down for it!!!!! Anything bigger what the 48mm is I’m sure it’ll give some oomph in the butt dyno -
Lol I mean I’ve had time off but mainly to travel to different cities... best one by far was dc on 4th of July...
Looking good bud, love that your enjoying the truck look into the aussie I have one in mine with no issues by far....
- 103 replies
- 98 conversion
- bushwacker
(and 3 more)
Tagged with:
What’s up fellas haven’t been on in a while... cps decided it didn’t want to work anymore good thing I keep a couple spares, Front driver side brake caliper seized on me on the way to pick up a Comanche specific topper gotta pick up parts Monday to swap new brake parts on.... currie axle side joint popped loose as the snap ring came out of place...gotta fix that and still got a pile of parts to install but haven’t had the time due to working 7 days a week for almost 2 years now....
Discount code doesn’t work just tried on the site unless it was only for the weekend
"Wendy"- 88 Jeep Comanche Build
88whitemanche replied to Swampy's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Looking good bud gotta paint that front bumper though lol -
Replacing oil dipstick o-ring
only spot that has oil on the engine currently and for sure I’m losing oil and i am quarts shorts when doing oil changes
