WolverineCub
1096 profile views
WolverineCub's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. Still looking to replace the idle control sensor. I see this one that looks right but it says it doesn’t fit the Truck? https://www.ebay.com/itm/292748451854?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=UkUsfFhuQnq&sssrc=2349624&ssuid=7t6LpLKKR_O&var=&widget_ver=artemis&media=COPY
  2. Need a hood latch for my 1988 Comanche
  3. I have a problem with my Jeep stalling. The picture shows the idle control. Mine does not look the same as what I can Order?
  4. I put grease on the bare metal. Looking closer at it, I think it can be fixed in the Spring and like I mentioned, I have a 1986 in the Yard. I live in Montreal, Quebec, the Cold Country.
  5. Thanks everyone. I will look for a body man that can do it.
  6. Maybe a body guy can pull it out. Has as anyone done this area before? Thank You
  7. I didn’t do the Body. I removed all the paint and welded in metal. I would need this done and painted Colorado Red. I don’t think it can be properly done without using the ends from my 1986. The 1986 is in my Yard. I took much off of it for this one including the tail gate.
  8. Hello, Last year I spent 7 months restoring my 1988 Jeep Comanche. I used many ideas from this forum. I am still working on it. One thing that needed attention was a broken weld holding the bumper on. I temporarily had 3/8” tye wraps holding it in place. Two weeks ago I ran into black ice and lost control. The Jeep went from side to side on the highway. It swerve to the passenger side and hit a small pole that pulled the bumper off. The bumper is scrap and the bed body in the rear now needs body work. The only thing I think would work is cutting the damage area out and welding the back with the same from my 1986 Comanche I have in the Yard. Ideas? I love my Jeep Comanche Thank You
  9. I had an issue of leaks from that area. I used black Polyurethane used for windshields to seal around the fuse-box. I also used the silver sheet plastic for insulation in the house, I wrapped it around the plug and secured with a tie wrap. Don't forget to check the Master Cylinder above it, that has only a sponge seal, mine leaked. I pulled it out and used the Polyurethane there also. No leaks at all after that.
  10. Do Wiring Diagrams change for each year? I have a 1988, will the 1987 (70 series) 8980 010 491 work?
  11. I have the ones at Amazon, same as on eBay but don't fit. The plastic lugs or tabs are off. Any others that don't need modifications? I look for Ford, same thing. PartsSquare
  12. Looking for 1157 and 1156 light sockets source
  13. Finally used black urethane on both sides of the Master cyl. and around the fusebox. NO MORE LEAK.
