mkbruin
Everything posted by mkbruin
MJ differential swap questions
mkbruin replied to big66440's topic in MJ Tech: Modification and Repairs
If you are looking for a drop out 3rd, stronger than stock, and disc brakes, why not go to the ubiquitous 9"? Parts everywhere, significantly more info online, cheap and proven workhorse... -
Nope. I put 5.5 on mine & never changed the drive shafts. When I did SOA on my 89, I didn't change the shaft. Driving down the highway the first time at 60mph hit a gentle riser, rear lifted and the DS dropped out of the transfer case. Blew up my rear axle internals. At that point I had a custom shaft built at a local shop that usually builds shafts for drag racers. Exact length based on my measurements, high angle yoke, massive tube, new u joints, fully balanced, and I was $125 out the door.
Not true at all on the first count. Harness only, stock lights, before and after, Stolen from a thread at JF: Big difference.
Yep. Lived in Denver my whole life, moved to Indy last Aug. Bought the XJ last week out of Denver and am driving it back this weekend. I've got family in Louisville... somewhat similar in KY, but not nearly as bad as Indy.
Keep in mind the 00-01 XJ got the 0331 head that WILL crack. Not a question of if, but when. 97-99 are easily the best years. Be patient, and look in rust-free areas of the country. statewidelist.com is a good resource. I picked up a 98 XJ with 118k miles for $1,900 +$90 for flight and $200 in gas. I could not touch anything local in similar condition for less than DOUBLE that cost.
I bought this one off Craigslist (located out of Boulder) last week... $1,900 and all it needed was a clockspring.
So.... he put on a bad TPS, then tried to get you to buy a trans rebuild after his part was bad? Sounds like you need a new mechanic.
RE 4.5 ZJ coils RE fixed lowers RE adj trackbar JKS Disco's SOA rear custom driveshaft ~32" tires (that was a long time ago, don't remember the exact size)
Seafoam the crankcase and the intake. Replace all plugs/wires/distcap. Oil change. Seafoam in the gas tank (2nd best. Best is to drop and drain the tank, start over).
I've put this up a long time ago. Should answer your question.
That link is pretty much the leaf spring bible over at Pirate. It has been viewed and gone over by thousands and thousands of people, many of whom have verified the info on the sheet. The info there is good.
I am an evil banker. Mortgage servicing. Specialize in investor portfolio management and foreclosure oversight.
All my stuff I either grab at a junkyard or from Certifit. For new parts from Certifit: Fenders: $80 ea Grill: $12 Headlamp doors: $20 Front panel: $40 Side marker lamps: $15 park lights: $20
1989 mj front end in a 1996 zj
mkbruin replied to daltonmcgill7's topic in MJ Tech: Modification and Repairs
you say the bushings are shot... as in control arm bushings? There are no bushings on the axle, so its not worth swapping that out. Bushings are CHEAP and easy to do. -
Bright sealed beam headlights?
mkbruin replied to Eagle's topic in MJ Tech: Modification and Repairs
In the post directly above yours I posted two other sources. Amazon direct, and eAutoworks direct. Both say the harness is made by Pimco. -
look closely for a "1" at the very beginning....
This work? http://www.ruffstuffspecialties.com/cat ... de=78x34RE
I've never had a sealed beam unit that performed worth a damn. Ever. On my last XJ, I used the eAutoWorks harness (now labled as Putco) http://www.amazon.com/gp/offer-listing/ ... dition=new or http://www.eautoworks.com/Putco-H4--900 ... D7540.aspx And combined them with autopal ecode headlights and 100/55 bulbs. Knocked the socks of any sealed beam I've ever used, and its EASY to do. When I do it again (and I will) I'll still use the harness, but switch to Hella housings and IPF bulbs. -
Recommendations on radiators?!
mkbruin replied to Dirteatr717's topic in MJ Tech: Modification and Repairs
I used a 3 core GDI back in the day when every forum on the planet had group buys on them. LOVED the 3 core. Just make sure you get all metal, not one with plastic sides. Its worth the extra $75 in the long run. Only cheap out if you plan on selling soon. -
Drive shaft angle with SOA question
mkbruin replied to Paul Bruchal's topic in MJ Tech: Modification and Repairs
Yes, all stock. '89 SporTruck, 4.0/AX15/231, D35 rear. -
I think ALL WJs have the chip. In '99 there were only the Laredo and the Limited. I had a Laredo and it had a chip. If I could possibly have ordered it without it I would have, but there was no delete option. Worst vehicle I ever owned. Yep, all WJ's are chipped for the ignition... but blanks still work in all the doors just to unlock.
When I SOA'd mine, I needed a new rear d-shaft. A local speed shop fabbed one up for ~$100. The factory rear shaft was so short, when I hit a gentle riser on the highway the shaft slipped all the way out of the tailcone, dropped to the ground and grenaded my rear end. I had to be flatbedded home. Keep driveshaft angles in mind: -
These are what I put into my last MJ http://www.monoprice.com/products/produ ... 1&format=2 Awesome sound. Monoprice sells some pretty darn good stuff.
