daltonmcgill7
    jacksonville,florida
daltonmcgill7's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. i also thought there was a little spacer but shen i took it all apart i didnt see any. but i didnt disconect the fuel rail completly but tomarrow when i redo it I'm gonna take the fuel rail off. then put the injectors in one by one into the fuel rail.
  2. and also these http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_fuel-injector-o-ring-assortment--universal-dorman--help_9110126-p?searchTerm=%2390100#fragment-4
  3. iv done some research and i think these are the o rings i need are these the ones you got? http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=FPGES70599_0147673119also do you know what those little clips are called I'm having trouble finding them thanks alot youve been a great help
  4. Thank you very much also does anyone know where to get one of the little clips that connect the injector to the rail i have lost one :doh:
  5. thank you i might go that way if my injectors are bad after i change out the o rings but i havent had the truck running in about 5 years. And before i go dumping money into i wanna get it running first I'm looking for just the orings there self.
  6. Mine were all brown I'm thinking they have me the wrong ones does anyone have the exact part number?
  7. well i went to advance got new o rings installed them and my injectors are still leaking not all of them thoguh there leaking from the orings shoul i just let it sit and maybe it will seal?
  8. i am also missing one of the clips that connect the fuel rail to the injector where could i get one of them or what are they called?
  9. well what should i do take the fuel rail off and remove them one by one change the o rings then reinstall them? should i get fuel injector cleaner or is there a way to clean them when i have them off?
  10. My injectors are leakingfrom the rail and manifold. What do I do to fix it it won't start?
  11. i don't have my fuel sender its broken.
  12. thank you so much this is what i was looking for. :banana: so your saying put a peice of hose where the fuel pump is now?
  13. ok thanks :thumbsup: could i use the stock gas tank use my fuel pump that dosent work and put it all back together and run the external pump?would that work?also i don't have anything but the pump and bracket it sits in no strainer or float.or can i just put a fuel filter between the gas tank and the pump
  14. Well my fuel pump is fried oh well what would be the cheapest pump I could use so that I can get it running its been sitting for 5 years not running
  15. i found my old pump after hours of looking i knew i had it somewhere but the strainer and fuel sender is missing and i honestly don't care how much gas i have ill just keep a gas can.but where could i get a strainer and how would i put it on.
