Pete M Posted January 21, 2018 Share Posted January 21, 2018 I've been holding off the new push for content additions until we get our "auto-shrink size of uploaded photo" code working. Since that is getting closer, I figure it's time to start thinking about what's the best way to make use of this new found power. we definitely need to go through the DIY list and fix broken links/pictures, but what new writeups would you like to see? Quote Link to comment Share on other sites More sharing options...
MeanLemons Posted January 21, 2018 Share Posted January 21, 2018 I have been working on a write up. Maybe when I’m done, I ll submit it. Quote Link to comment Share on other sites More sharing options...
DirtyComanche Posted January 21, 2018 Share Posted January 21, 2018 If somebody wants to do a LS swap how-to, I'd appreciate it. Quote Link to comment Share on other sites More sharing options...
Sir Sam Posted January 21, 2018 Share Posted January 21, 2018 4 hours ago, DirtyComanche said: If somebody wants to do a LS swap how-to, I'd appreciate it. Well thats simple, drop the Jeep and your blank check off at the shop of your choosing. Quote Link to comment Share on other sites More sharing options...
kryptronic Posted January 21, 2018 Share Posted January 21, 2018 Complete air conditioning delete would be on my short list. Quote Link to comment Share on other sites More sharing options...
ComancheKid45 Posted January 21, 2018 Share Posted January 21, 2018 An exhaust manifold replacement walkthrough I think would be helpful to alot of members 👍 Quote Link to comment Share on other sites More sharing options...
Kyleinreallife Posted January 22, 2018 Share Posted January 22, 2018 How to un@#$% PO's shoddy work?87' XJ Wagoneer I-6 AW4 NP242 Quote Link to comment Share on other sites More sharing options...
Ωhm Posted January 22, 2018 Share Posted January 22, 2018 Define all fusible links by year, engine, model. Quote Link to comment Share on other sites More sharing options...
Old man with MJ Posted January 22, 2018 Share Posted January 22, 2018 Disk brakes from a Liberty install Quote Link to comment Share on other sites More sharing options...
mark 39 Posted January 22, 2018 Share Posted January 22, 2018 1 hour ago, Ωhm said: Define all fusible links by year, engine, model. ^ +1 Quote Link to comment Share on other sites More sharing options...
Kickin’Chicken Posted January 22, 2018 Share Posted January 22, 2018 Cherokee donor vehicle to MJ - engine, wiring harnesses, computers, dash, et al..... Quote Link to comment Share on other sites More sharing options...
PIKE Posted January 22, 2018 Share Posted January 22, 2018 Upgrade 4.0 Renix jeeps to the newer automatic serpentine belt tensioner if its possible. Quote Link to comment Share on other sites More sharing options...
DesertRat1991 Posted January 22, 2018 Share Posted January 22, 2018 - A/C install on a non-AC truck - Cruise control install - How to build that carpet panel that's supposed to go behind the seat. Can find any good shots of how the OEM panel mounts. Quote Link to comment Share on other sites More sharing options...
DesertRat1991 Posted January 22, 2018 Share Posted January 22, 2018 On 1/20/2018 at 5:39 PM, DirtyComanche said: If somebody wants to do a LS swap how-to, I'd appreciate it. I can't wait for the first Hellcrate Comanche to show up...! Hell-Manche? Quote Link to comment Share on other sites More sharing options...
Skorpyo Posted January 22, 2018 Share Posted January 22, 2018 In trying to think of articles that would help reduce the myriad of repeated questions: Axle swap options, consolidated brake options (discs, boosters, valve/delete), vacuum diagrams and functions, lift/tire/gear combos, TPS/CPS/IAC/TB checking, No-Start/Stumble/Idle issue check diagram with logic flow, Seat/Bracket swap options. I'm sure there are more pressing ones, but that's off the top of my head. Quote Link to comment Share on other sites More sharing options...
cruiser54 Posted January 22, 2018 Share Posted January 22, 2018 20 hours ago, Ωhm said: Define all fusible links by year, engine, model. And color. I used to have that chart from Jeep. Quote Link to comment Share on other sites More sharing options...
Eagle Posted January 23, 2018 Share Posted January 23, 2018 10 hours ago, PIKE said: Upgrade 4.0 Renix jeeps to the newer automatic serpentine belt tensioner if its possible. What automatic serpentine belt tensioner? I have two 2000 Cherokee 4.0Ls. They don't have an automatic tensioner, I have to do it manually. Quote Link to comment Share on other sites More sharing options...
DirtyComanche Posted January 23, 2018 Share Posted January 23, 2018 1 hour ago, Eagle said: What automatic serpentine belt tensioner? I have two 2000 Cherokee 4.0Ls. They don't have an automatic tensioner, I have to do it manually. Maybe on the WJ? I don't recall how they're set up. The ZJ still uses a manual tensioner, it's a lot nicer setup than in the XJ though. Quote Link to comment Share on other sites More sharing options...
omega_rugal Posted January 23, 2018 Share Posted January 23, 2018 a service manual for the 4.0 HO woudl be nice Quote Link to comment Share on other sites More sharing options...
Sir Sam Posted January 23, 2018 Share Posted January 23, 2018 2 hours ago, Eagle said: What automatic serpentine belt tensioner? I have two 2000 Cherokee 4.0Ls. They don't have an automatic tensioner, I have to do it manually. The WJs have an auto tensioner, and the alternator in a different spot, and AC is in a different spot. Buddy of mine went to the WJ setup on his XJ buggy to get the alternator up where the AC used to be, and he runs the auto tensioner with a shorter belt. Nice if you want the higher amp WJ alternator, AC delete, and run a 99+ intake. I don't think you could make the WJ auto tensioner work with the stock AC comp and alternator setup. Quote Link to comment Share on other sites More sharing options...
IronManche87 Posted January 23, 2018 Share Posted January 23, 2018 - A/C install on a non-AC truck - Cruise control install - How to build that carpet panel that's supposed to go behind the seat. Can find any good shots of how the OEM panel mounts. X2 on the cruise but for a RENIX as there's already a HO install write up.Sent from my LGMS210 using Tapatalk Quote Link to comment Share on other sites More sharing options...
schardein Posted January 23, 2018 Share Posted January 23, 2018 20 hours ago, DesertRat1991 said: - A/C install on a non-AC truck - Cruise control install - How to build that carpet panel that's supposed to go behind the seat. Can find any good shots of how the OEM panel mounts. I've got some pics of how the panel mounts I can post later. On the belt tensioner, if you have an HO and can swap to the late style manifold, which requires a different P/S pump mount, the belt adjustment is MUCH easier. I'd say almost worth doing the swap alone, besides the better manifold. Quote Link to comment Share on other sites More sharing options...
coolwind57 Posted January 23, 2018 Share Posted January 23, 2018 19 hours ago, Skorpyo said: In trying to think of articles that would help reduce the myriad of repeated questions: ...consolidated brake options (discs, boosters, valve/delete), vacuum diagrams and functions, lift/tire/gear combos, TPS/CPS/IAC/TB checking, No-Start/Stumble/Idle issue check diagram with logic flow... I second all that. I did a front proportional valve delete for my brakes and love the results. I have pics for a write up. Identifying location and describing function and troubleshooting of each vacuum/electrical/mechanical component under the hood. Like Skorpyo said, it sure would cut down on commonly asked questions and really help out newbies. Quote Link to comment Share on other sites More sharing options...
Goose_XJ88 Posted January 24, 2018 Share Posted January 24, 2018 On 1/22/2018 at 8:21 AM, DesertRat1991 said: - A/C install on a non-AC truck - Cruise control install - How to build that carpet panel that's supposed to go behind the seat. Can find any good shots of how the OEM panel mounts. Here are the only two pictures that I have found over the past year or so to try and figure out the mount.. screenshot was from a YouTube video Quote Link to comment Share on other sites More sharing options...
zomeizter Posted January 24, 2018 Share Posted January 24, 2018 Tutorial on fiber glass application? Quote Link to comment Share on other sites More sharing options...
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
