PIKE
    Catron County, New Mexico
PIKE's Achievements
Comanche Aficionado
Comanche Aficionado (4/11)
  1. 1989 Comanche Pioneer - Carpet
  2. This is a picture of the sticker that was behind the seat of my 1989 Comanche.
  3. I hope its ok to do this. I have a SKF unit bearing that fits a 1989 Comanche for sale on ebay for $20.00 starting bid plus shipping. It is brand new never used. SKF has had problems with counterfeiters. I know this is the real deal because I purchased it directly from SKF. When I received the hub it had a minor flaw and they sent me a new one. I think it would work perfectly fine and you might even be able to fix it. https://www.ebay.com/itm/327214584581 SOLD
  4. Have you installed after market shackles ? Many after market places sell the same shackles for XJ's and MJ's. The steel bushing inside the rubber on a XJ shackle is 2.715" long. The steel bushing on an MJ is 2.815" long. I found this out after I bought some shackles from Rubicon Express. I have clunking too.
  5. Another vote for LuK. I have one in my Ford 7.3 Powerstroke F350 and my Comanche 4.0 AX15. The one in my Comanche is the Pro Gold version.
  6. There was also a short round tube that would go with that under the cap originally, I haven't been able to find one. I think it was to prevent coolant from sloshing out the cap since it is vented. Number 9
  7. The expansion bottle from a 2.5 liter works very nicely with the Macs tank. It bolts right in, the mounting holes are already there. https://www.quadratec.com/products/51216_02.htm?gad_source=1&gad_campaignid=19472278524&gbraid=0AAAAAD_wpjimqWgguCgVpB6d83jQ2KQ0l&gclid=CjwKCAjwi4PHBhA-EiwAnjTHuSHNute531deQ-asKqcdWeqKsHb1cH5bsOR2Dl948PO8905E3VziIhoC_M4QAvD_BwE
  8. Nice, thanks for doing that. I can definitely see how the 1238 is beefier. It allows you to use the larger tie rod ends. The DS 1312 which is the tire rod for a V8 ZJ allows you to use the larger tie rod ends also.
  9. Interesting that its almost an inch longer. Would be interested to see the DS1311 side by side with the DS1312. I read that the V8 tie rod is beefier than the 4.0 but by how much? Let us know how it works for you. Tie rod, Drag link, Center link, Connecting link, which is which? My head is spinning, haha
  10. DS1311 is for the 4.0 Grand Cherokee ZJ. You want the DS1312 which is for the V8 Grand Cherokee ZJ and beefier. I have 4.5" lift on my 89 Comanche and the parts I used work just fine. Conversion Part #s. MOOG DS1312 MOOG DS1238 MOOG ES3096L - 2 needed MOOG ES2079S - 2 needed
  11. MOOG DS1238 Drag Link $ 43.99 at Rock Auto
  12. The Drag Link part # he shows in his link is wrong, it should be a Moog DS1238. That is the Part # I used when I did my conversion and everything went together perfect. I agree with all his other part #s. The Ds1238 is for a 91-01 Cherokee. The number he shows is for a Grand Cherokee and does not work well as you found out. Conversion Part #s. MOOG DS1312 MOOG DS1238 MOOG ES3096L - 2 needed MOOG ES2079S - 2 needed
  13. To tell you the truth its been over 2 years since i installed the stabilizer and can't remember what i torqued it to. I found this chart. Hope it helps you out. https://www.fastenermart.com/files/metric_tighten_torques.pdf
  14. i have the Rough Country N3 on my MJ. Very beefy, I like it. Goes good with my Clayton trac bar which is pure beef.
  15. SKF 11800 is the seal I used inside the differential housing.
