AnotherOldJeepGuy
AnotherOldJeepGuy's Achievements
Comanche Addict
Comanche Addict (5/11)
  1. A reasonable thought. I feel like the sound was different than that but I can't be sure.
  2. This morning when I left the house a loud static noise came from behind the dash. It lasted maybe 15s and then stopped. It sounded like noise from a speaker when an amplifier was crapping out, but AFAIK there's no speaker back there. It wasn't RPM related. The cab fan was in the OFF position, but I did turn it up and down through the speed settings, the fan worked in each position (it's a new fan from last summer) and that had no effect on the sound. I do know that sometimes when I first head out my speedometer needle bounces a bit at low speed (under 10 MPH) for a couple minutes which results in a tapping sound in sync with the bounce. But this sound was not that. I turned the radio volume completely down just in case even though I know the speaker is not behind the dash, but that had no effect on the sound. It happened twice separated by no more than a minute and the second time lasted about the same amount of time. There was no third instance of the noise. The truck was running normally. I did later look under the hood just to see if maybe a critter had put something in there that was being whacked by the fan, nothing there. Anyone have any idea what the heck this might have been?
  3. Armed with the detail from @fiatslug87 in my pocket I proceeded to disassemble rather than dissect. After disassemble of the outer parts I did still have to pull the door open with some force, but it was not as stuck as it was originally, and luckily nothing else broke doing that. With door open I could remove the latch assembly, and see what was broken. It looks like the lock assembly is held in with tabs so I am hopeful once I get a replacement latch I may be able to swap in my keyed assembly. Although pulling that out might let out all the rest of the guts fly out, so I guess I'll cross that bridge a bit later.
  4. Great, I'll give this a try.
  5. Good input! I didn't think of that.
  6. Is there both a "grey" and a "dark grey" interior for 1990 MJ, or just one grey option?
  7. Happy Turkey Day everyone!
  8. It feels like the button to the left may be functional but the button to the right is no longer working. I've squeezed and wiggled as much as I can without tools with no luck, my next attempt will be using some channel locks to see if squeezing harder might do it. If not my plan is to slowly dissect the latch mechanism from the outside with a Dremel cutting wheel trying to keep the lock assembly part intact with hopes of reusing that part. I'll takes some pics along the way and share the process if it works. Looks like there's a decent amount of replacements on Ebay for not too much cost just need to get the old one out somehow.
  9. Thanks for the pic. That's the one I remember and liked it much better, until it finally wore out and split. There's a mountain of the wrong ones on ebay, but none of those! I have a friend that makes it to the yard from time to time, now that I have a pic to give him I'll ask him to look. If you have an extra you would turn loose, send me a DM.
  10. I was not able to 100 percent get the dye off of the inside of the cap, so this next test may be destined to fail regardless, but it's what is available. (Actually I think I have a spare cap in my glove box, but when I tried to retrieve that, my next thread got started ). Will see what this test captures over the next 50-100 miles while I await my blackstone report....
  11. I searched here for good "how to" to get my glove box open, but didn't find any that was all that helpful. Taking a prybar to it didn't seem like a good choice, and pulling the dash is not on my to do list ever. My latch has been a little contrary for a while, but today when I tried to open it, no luck. The key still turns and it does appear to go in and out of the intentional lock position, but in unlock it won't release. If anyone can provide clear guidance on how to get this open without breaking it, and without removing the dash (assuming one could even do that without access into the glove box in the first place, ) I'd love to get that solution! And one with pictures much better.
  12. That sounds like the one I need, any idea where to get it?
  13. As you can see, there is evidence of a leak at the cap! I was able to clean up the threads at the bottle close to 100% to see if it comes back, but getting the cap completely clean is turning out to be less successful. Seems like the dye has worked it's way into the cap plastic some although I can minimize it. Gonna try letting is soak a while and see if I can "un-dye" it. EDIT: I never liked this new cap, it is about 1/4" taller than the original that split a few years back and originally it touched the inside of my hood. I tapped the inside of my hood where it touches to squeak in a bit of clearance. If this continues to seep out coolant I'll try harder to find an original height cap. (To the Star Trek fans, I really wish I could get a replacement tank made of the transparent aluminum Scotty created for the whale tank).
  14. There isn't any residue at the tank hose connections (or any other connections for that matter), but there is a small amount of residue at the cap. The residue doesn't venture out away from the cap so it is limited to right at the cap. I'll get a pic or two and clean up at the same time to see if it comes back. Haven't driven much in the last 3 days so haven't checked the level again yet. The last time I tried burping it was when I put in the new T-stat housing, the truck was basically level. Don't know what a combustion leak tester is so that is not a test I have done. I don't have the equip needed for a pressure test either, so my version of pressure testing is look for leaks when the engine is running.
