tarmac2dirt
tarmac2dirt's Achievements
Comanche Fan (3/11)
hello, Picked up a ax15 for my 88 MJ which is going in with my new 4.0 engine i built. i have been looking for a similar 2wd tail shaft and can not find one like this. Has a rear seal guard and a thick web under for i guess a vibration damper of some kind. Just seems to be a odd tail housing. Any one know what it may be, I don't see a reason it won't work. Thanks, Paul
Hello, As the title shows, how are you guys installing the the oil pump screen to a new oil pump ( screen is new too). I know its a press fit but are you guys using any special tool. I have seen a driver on you tube and found them for sale on several suppliers. Other ppl claim to use a 5/8 or 16mm open end wrench around the tube. Others heat the pump body and chill the tube to help with the press work. Or is it just a real pain to get it installed. Would definitely like to know how you guys are doing it. Thanks, Paul
I'm having to replace the oil pan on my new rebuild, 94 4.0l. Are there any pans that are better in fitting the block. i see several on rock auto with a big price difference. Just like to buy a good replacement without any future problems. Thanks, Paul
Hello, building a 4.0 for my jeep Comanche. This is a stock rebuild not a stroker. i have started checking all the gaps and clearances and have come up with no recommended ring gap for parts i have bought. The pistons a sealed power h802cp and matching ring set. There are no ring gap notes anywhere in the boxes, as compared to the stock pistons the sealed power pistons are hypereutectic and i know the ring gap needs to be wider than stock specs. i have come across the Keith black spec chart and it shows .0065 per 1" of bore dia. Is this applicable to all hyper pistons?? Out of the box i have .017 on my top ring and .017 on 4 and 2 at .018 on the second ring gaps. Keith black hyper specs calculate to about .025. should i go with .0065 calculations? comparing the stock and new pistons the top stock top ring land is at .321 and the new hypers are at .245, much closer to the top. I have also decked the block .020. What would be a some of your suggestions for the proper end gap. This engine will be a dd not needing any performance of race type specs. Thanks for any advice, Paul
Getting ready to order the second half of the parts i need for my engine build. Orig header pipe is cracked so i have to to get a new one. This is a 1994 block, head and intake going into my 88 MJ 2wd. Theres this ATP header #101212 on rockauto $205 any have experence with this or do step up to a better one. Can't really afford the banks header, are their other options that I'm not finding. can someone maybe give me some insight on something good and quality wise or is the ATP header decent. Thanks, Paul would anyone care to see pics as i go through my build
ive run across an issue with the knock sensor threaded hole in the block. The threads in the block where the sensor goes is very rusty and crusty. Looks like about half of the threads have rusted away. This block is a 1994 which i guess they did not have the sensor? Any way has any one done repair work to the threaded hole as put an insert in there or any other option to fix it. I'm using this block in a 1988 MJ which is of course a renix electronics . Thanks, Paul
engine accessories left on
tarmac2dirt replied to tarmac2dirt's topic in MJ Tech: Modification and Repairs
i am going to go ahead and remove the p/s pump to rebuild. the radiator will be out not the a/c condenser; water pump off was really concerned about the intake and header. -
As the topic says, how much of the accessories can be left on an engine when removed. when i get around to pulling mt engine for the swap i would like to do most accessories om the engine stand. Such as intake, header p/s pump and alt. this will be done with the trans off. hood off and the radiator support in. What can you guys tell me if any has to come off. I will also be doing this by myself, i will have no help. Thanks, Paul
Will be building a new engine soon (4.0) for my 88 MJ. At the same time I'm going to replace the clutch. What are you guys using as a good upgrade clutch for an engine with very minor mods. LUK--Precision--MPAC--ECT. so many to pick from off rockauto. At this time, I'm just collecting some parts before i dig into the engine parts for pistons and cam. This will be a dd and not a stroker engine, just a good built 4.0. I had a clutch replaced in 2007. but don't know what brand it was. It served me well. Please let me know what you or your buddies believe is a good replacement. Thanks Paul
Ok guys, a few answers about cams and using certain spring pressures, but your not answering my question. can a thrust plate type cam be used in a early type block. The cam companies do not have the early blank cores to even grind a cam. I did find one company that has some blanks for 1999 and newer ready to make me a custom cam but will it WORK thats what i want to know. The cam cores for early blocks seem to be hard to come by for cam grinders. Any hope to get the correct answer here. Thanks
i'm starting a new engine build 4.0 starting with gathering the parts needed. Seem like the 96 cams are like getting fresh dino dung. Can the 97 and later cam be used in a 1994 block. I know it has a retainer plate the can be eliminated by using the early cam bolt and button up front. Is there any other problems that stops me from using a newer type of cam. Oh yes i know comp cams shows early cams available but their quality is crap so no comp stuff for me. thanks Paul
Ok, gives me the work plan on what i need to do. Have to pull pan to see were a load knocking noise is coming from. i screwed up and left a scott paper towel in the filter intake and now created a lot of work ahead. thanks for the answers, Paul
need to pull the oil pan and was wondering if the pan will come off with engine in the chassis. Looks like there is enough room. this is a 1988 2wd MJ if that matters. thanks Paul
Well it seems to have dropped about 4mpg from what it used to be. Ran a trip of about 120 miles and refilled the tank and calculated at 13.8 mpg. does this seem low to you guys. This is a stock 1988 MJ long bed 2wd 4.0 engine with 706 injectors and a 60mm throttle body cruised at 65 with a/c on one way and off coming back home. Tires are a little larger 30x9.5-15. I kinda thinking the O2 sensor is bad, happened once befor about 10 years ago. change the O2 and got my mileage back. Does it sound like the sensor has gone bad again. probably has about 60k since the last sensor change. Is that about limits for an o2 sensor 60k miles. I'm going to go ahead and chane it but is the any other things killing the mileage, MJ is at 200k on the clock so it is getting tired too. thanks Paul
As the title shows the chrome trim work above and below the grill. Going to try and refinish the shine but not ruin the metal. A magnet will stick to it but that doesn't mean its a pure stainless. Doesn't look like its chrome plated I'm just not sure. Anyone have an answer. to this. Thanks
