Kyleinreallife
Everything posted by Kyleinreallife
  1. I wouldnt be be able to properly explain the issue to them....maybe one of the admins can do that when they get a chance?
  2. Ohhhhh makes sense, did you update recently? Just wondering why this just started happening, if they haven’t updated since 2017
  3. Bump. Anyone working on this? Id be down to use CC in the browser if 1. It was the only forum I source info from and 2. It was anywhere near as organized as tapatalk... itd be be nice to not have to make a new account, but I’d be willing to get tapatalk to work. Mods? Admins? Bueler? I'm almost positive the issue is on the CC side of the tapatalk/cc interaction...
  4. Bump. Any update on this issue?
  5. Nope :/ I click login in, takes me here: i click yes and it takes me here: click okay and try to login with both my user name and email and I get this: ...this is where it loses me.... I can login through the web just fine though...issue with CC/tapatalk interfacing?
  6. Thanks cruiser! I forgot you specified that on there. Doh!
  7. Nope :/ I click login in, takes me here: i click yes and it takes me here: click okay and try to login with both my user name and email and I get this: ...this is where it loses me.... I can login through the web just fine though...issue with CC/tapatalk interfacing?
  8. I’ve been having issues with tapatalk and the forum lately...I can’t sign in and my sig keeps disappearing, I had all my info there. I'm not sure how to fix it ive updated my phone and the app. CC is the only forum giving me issue in the app so I’m assuming it’s on that side...
  9. I thought that was only the location on mjs? Thanks!
  10. Where is it? Bonus question: Anyone else having problems with tapatalk? this is what I get when I try to login to cc from tapatalk I can log in to tapatalk fine, just not cc through the app
  11. Will do 87 XJ Wagoneer Ltd I-6 NP242 AW4 HPD30/D44
  12. Mine is absent... 87 XJ Wagoneer Ltd I-6 NP242 AW4 HPD30/D44
  13. What does the ballast resistor do? 87 XJ Wagoneer Ltd I-6 NP242 AW4 HPD30/D44
  14. Okay, so just don’t run vacuum to the charcoal canister? 87 XJ Wagoneer Ltd I-6 NP242 AW4 HPD30/D44
  15. Okay, I’ll put the vac canister back and plug the egr line. Map is getting vacuum from the throttle body. Do I need the charcoal canister or can I just run the fume line straight to the manifold? 87 XJ Wagoneer Ltd I-6 NP242 AW4 HPD30/D44
  16. I’m not really concerned with it rn, I’m trying to fix the running issue. The aux fan works on the switch. Today I got rid of as much as I could of the vacuum system. I deleted the vac caninster, charcoal canister and cruise control. I have vacuum direct from the manifold to: egr solenoid, fuel tank fumes, fuel pressure regulator and heater control. Can I block of the egr? Or remove completely? I’m not concerned with passing smog, I can “pay to pass”. I want to remove as much unnecessary stuff as possible. When I say necessary I mean for the motor to run smoothly, not cleanly. 87 XJ Wagoneer Ltd I-6 NP242 AW4 HPD30/D44
  17. There wasn’t a factory aux fan, PO put one in. Poorly. The relay nearest the front is for the aux fan he put in. It’s on a rocker switch. The relay nearest the fire wall is what I’m wondering....The wires go into the harness and I haven’t opened it up to find out. I’m starting to think my whole manifold was swapped at some point. I’ll post a pic of my engine bay in a few. As I started replacing parts the more I found that wasn’t stock. Egr was off a Le Mans Map was a GM O2 sensor didn’t look like any of the replacement options at oreily CAT was gutted 87 XJ Wagoneer Ltd I-6 NP242 AW4 HPD30/D44
  18. Isn’t the coolant temp up by the water pump? 87 XJ Wagoneer Ltd I-6 NP242 AW4 HPD30/D44
  19. Anyone know what sensors these are? Driver side on the block 87 XJ Wagoneer Ltd I-6 NP242 AW4 HPD30/D44
  20. The one forward of the egr solenoid is the fan relay... 87 XJ Wagoneer Ltd I-6 NP242 AW4 HPD30/D44
  21. Cleaning up wiring..what’s this for? 87 XJ Wagoneer Ltd I-6 NP242 AW4 HPD30/D44
  22. As long as the hoods not closing on it I think you’ll be alright. Imma be working on mine this weekend if you wanna bring Minnie by for a bit. 87 XJ Wagoneer Ltd I-6 NP242 AW4 HPD30/D44
  23. You know I have vac fittings in the xj dog! You think I wear that Calvary hat for nothing? 87 XJ Wagoneer Ltd I-6 NP242 AW4 HPD30/D44
  24. Gotcha thanks. I’m having the same issue as you except I’ve already replaced the vac lines, tps, egr, map, iac, cap, rotor, plugs, wires....I’m thinking maybe I didn’t hook the vac lines back up properly 87 XJ Wagoneer Ltd I-6 NP242 AW4 HPD30/D44
