Everything posted by Kyleinreallife
Unfortunately no, I wasn’t a planned thing. I had gone out to a backcountry bar I know of to get some lunch, and decided to see where a fire road led to on my way home. This was literally the only spot I could’ve gotten stuck. God was lookin for a laugh hahah Sent from my iPhone using Tapatalk
My step dad had to come pull me out this weekend in his 85 Toyota SR5 pick up. So this question is for him. He was getting a sputtering under load. Checked the timing and it was forward. He adjusted and moved onto the plugs. One was fouled so he replaced, a brittle plastic connector broke off a sensor (I’m not sure which—it’s just below the tps). He took it for a test drive and said it’s got not power under 2k rpm now and has a hard time staying running at idle...anyone know yotas? Sent from my iPhone using Tapatalk
Yea I did, with some help. I made the mistake of going out alone and just doing some dirt fire roads. This little washout snuck up on me, as soon as my rear tires touched the corrugated pipe my @$$ end slid over. Happened around 5pm yesterday as it was gettin dark and rainy and out of cell service lol. Decided to leave it there overnight and jog 3 miles to the main road where crumbscomanche was able to pick me up and bail me out, praise jeebus. Sent from my iPhone using Tapatalk
Oh yea hahaha for suuure Sent from my iPhone using Tapatalk
Fixing door post hinges
Kyleinreallife replied to OLDsquaw's topic in MJ Tech: Modification and Repairs
Torch, melt everything clean. Reweld Sent from my iPhone using Tapatalk -
Should be zero resistance if it’s good? 87' XJ Wagoneer I-6 AW4 NP242
How do I test if the wiper breaker is good/bad? 87' XJ Wagoneer I-6 AW4 NP242
I wish! I have to do the rear main and solve this fuel issue. It’s running suuuuper rich and I got under 200 miles on this last tank 87' XJ Wagoneer I-6 AW4 NP242
Dang I just went last weekend! Have you heard of rower flats ohv area? 87' XJ Wagoneer I-6 AW4 NP242
Also, Has anyone any experience with actually replacing the vinyl with wood paneling? 87' XJ Wagoneer I-6 AW4 NP242
The wood grain is not my favorite on mine lol...I’ve been thinking of replacing it with 90’s rainbow holo-foil happy face pattern vinyl ....anyone know where I can find aaaaaanything like that? If you know what I’m talking about, is there a proper term for what it’s called? Think old LBZ sticker background... 87' XJ Wagoneer I-6 AW4 NP242
You’re driving a 30 year old brick. We don’t have the luxury of thinking about mpg....just tune everything to run well 87' XJ Wagoneer I-6 AW4 NP242
Unique No Crank Issue
Kyleinreallife replied to AeroNautical's topic in MJ Tech: Modification and Repairs
Will do, but yea I have tried, won’t start in anything but park when it happens 87' XJ Wagoneer I-6 AW4 NP242 -
I’ve noticed that when parking, if I make sure to begin firm and intentional when turned the key to off and putting into park, it reduces the chance of the no start. Leads me to think ignition or nss....i cleaned the nss recently...don’t know how to test electricallly though... 87' XJ Wagoneer I-6 AW4 NP242 -
This sounds similar to an intermittent no crank issue I’m having. Cranks and fires up 90% of the time. When it doesn’t want to start, with the key on, I can jump the starter with a screwdriver and it’ll fire up..and will start normally until the next time it doesn’t want to. Leads in where to begin? Where is the starter relay, what and where is the pdc? 87' XJ Wagoneer I-6 AW4 NP242 -
Yes. It’s awful. I’ve known people driving with dealer plates for over a year lol 87' XJ Wagoneer I-6 AW4 NP242
I know a guy... 87' XJ Wagoneer I-6 AW4 NP242
My cousin’s truck had one of those, that’d be the rear mounted fleshlight.. 87' XJ Wagoneer I-6 AW4 NP242
This is my first time troubleshooting an injector issue, could you give a little more detail? I’m not sure what 22lbs @ 39psi means, what is that referencing? And am I testing the injectors specifically with some sort of gauge? Or putting a gauge on the Schrader valve on the fuel rail? 87' XJ Wagoneer I-6 AW4 NP242
