mattbuch96
1 Follower
    Huntington Indiana
1439 profile views
mattbuch96's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. I recently just did the same upgrade, but I like your bolts, any chance you could share where you got them and what bushing and o rings you used? Thanks. Sent from my iPhone using Tapatalk
  2. I just did the swap. I used one off a 2000 TJ. Good upgrade. Here’s some before and after pics of mine feel free to ask any questions. Make sure you grab the valve cover bolts off the donor because they are a longer than the plastic one. Sent from my iPhone using Tapatalk
  3. Those look like alloy aluminum wheels, I don’t think they will ever rust, but I wouldn’t use a wire wheel. I would get some sort of aluminum polish compound and use a rag or a pad on a drill to polish them. I like the mothers polish, it’s a cream polish. Works really good. Sent from my iPhone using Tapatalk
  4. I believe either 3.55 or 4.10 Sent from my iPhone using Tapatalk
  5. I like the price of the Rusty’s, what do you think about Rancho? Sent from my iPhone using Tapatalk
  6. Throwing around the idea of upgrading my sway bar. Has any one ever used a ZJ or WJ sway bar swap, it looks possible but I cannot find any input else where. Thanks
  7. You don’t think the rough country fixed LCA won’t last?
  8. Thanks for the input, I will not do anything with the drop pitman arm, on the side note, I don’t want to have rubbing on the control arms at full lock, do you think the wj control arms would be better than the rough country fixed control arms? Or vise versa? Sent from my iPhone using Tapatalk
  9. Down the road I will be installing Rusty’s 3in lift and 31x10.50r15 tires along with my Napier fender flares, along with the lift I plan to use a xj drop pitman arm, zj tie rod end upgrade, and xj drag link, and Chevy drop shackles. My questions for you are is it necessary to get rough country’s fixed lower control arms or will do the Wj lower control arms be okay? Is there any sway bar upgrades like a Zj part? Thanks guys! Sent from my iPhone using Tapatalk
  10. Welcome to the addiction! Great find for $200! Looks like it could use a good scrubbing [emoji23] Sent from my iPhone using Tapatalk
  11. I have that bottom piece in your picture, the trim piece that is behind the seats. Sent from my iPhone using Tapatalk
  12. Dang, mine is 117.35 yearly in Indiana. I feel like it is way over priced. $12 in vehicle taxes, $20 county tax, $25 municipal tax, $30.35 registration fee, and $15 TLL fee. Sent from my iPhone using Tapatalk
  13. Just out of curiosity, what do you guys pay for annual registration for your Comanches? Mine is about the same for my daily driver which is 25yrs newer than my Comanche? Sent from my iPhone using Tapatalk
  14. Happy Birthday! Sent from my iPhone using Tapatalk
  15. I came across this on my local Craigslist, if found it quite interesting. What do you think? https://fortwayne.craigslist.org/cto/d/1989-jeep-xj/6400476712.html
