mancheflo
  • Interests
    1992 Jeep Comanche long bed 4.0 4x4
1909 profile views
mancheflo's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. what is a good sounding muffler/exhaust combo for these trucks? ive recently chopped my exhaust off due to rust and am looking to get it back to street legal. I don't want to spend an arm and a leg on a 28 year old truck, thanks!!
  2. Anybody know any way of testing to see if a fuel pump is bad or not
  3. Any thoughts as to if this could be a fuel pump issue? Ran for about a month or so then do the same thing and now nothing
  4. Had the battery tested while I was there, he also tested some other stuff and said it was getting no spark so idk
  5. So just got off work and going to auto zone to get a gift card for my father in law and as I pull into the spot the Jeep just turns off, it’ll try to turn over all lights on and battery is good, any ideas? I’ve never had any problems with it starting in the past even when it’s been below 20 Merry Christmas to me 🙃
  6. Alright well hopefully that’s it! Thanks man
  7. That’ll cause it to leak that much and even when it’s not been ran?
  8. And I haven’t ran it since Friday and this morning there was more fluid on the ground
  9. So I have this mysterious coolant leak going on and it just happened out of the blue, backed the truck up to unload some stuff 20 minutes later I notice this big puddle of fluid, I go look at it and it’s definitely coolant leaking but the reason it’s mysterious is that it’s leaking from the middle left part of the engine bay near the reservoir tank but the outside of the tank and near where it’s bolted in doesn’t seem to have any fluid on it but In the second picture I circled where there is some coolant but I’m not sure about it at all,
  10. I have a small pinhole leak in one of the power steering hoses
  11. Just put some old stock xj wheels on my Jeep and was checking the clearance out and as I had fully turned to the left and was checking it out and as I was looking I got sprayed by some fluid then looked into the engine bay and noticed some fluid in there too, could this be my power steering pump gone bad?
  12. Thanks! I’ll have to look into that!
  13. That sounds pretty cheap 😂 would I need new shocks and springs with that
  14. Any recommendations for a 2 inch lift or is there anyway to get that 2 inches of lift by any other way than buying a lift kit
  15. Would a hitch receiver from a jk work on our trucks?
