Crash
Everything posted by Crash
Overheating and loss of power above 2000 ft.
Crash replied to GrayWolf's topic in MJ Tech: Modification and Repairs
I have parts store 'spectra' rads in my heeps. No issues. For heater Hoses you can vo one of two things. Either get HO molded hoses or get adapters and cut in splice mid hose. Universal reservoirs available at local parts store. Most times you can remove spring from old hose and put in new- 11 replies
- overheating
- higher altitude
(and 1 more)
Tagged with:
Car Cranks but Won't Start Up
Crash replied to Comanchakazie's topic in MJ Tech: Modification and Repairs
There is this. Also, crank sensor, and asd relay can be culprit also. Attempt disco crank sensor and plug it back in, see if it fires -
They don't entirely, but the header fits with old fenders. Body line at the top is different though. Years ago, on my XJ I had just the panel for a bit before I got around to swapping fenders. As far as wiring, you can splice/the whole thing. Or just splce in the extra turn signal bulbs.
Couple of brake and steering questions.
Crash replied to Jeep Driver's topic in MJ Tech: Modification and Repairs
What is the bigger picture on this? You want stock width, stock bolt pattern, bolt in a housing (no changing brackets on the axle itself), with really big brakes? Why? What are you doing with it? It's going to be driven, hard. I just wanted to swap knuckles for 'big brakes'. I want Brembos and 14" rotors..........just what I want, but may have to settle for 4pot WIlwoods. Hey, if Jay Leno uses Wilwoods........... :P I believe I have a pair of early knuckles on a cad 30 in my back yard, if interested. -
I have currie steering on my renix XJ. May be selling it if I do stinky fab steering Synergy looks like a nice piece, but I do not own one. -
Non-cad was on 242 equipped vehicles.
Might try GT covers. I have some dash designs covers for buckets. And although they fit, the do not have an area open where the latch is. I just cut a hole in it large enough to make it work. To keep it longer possibly, may need to stich or whatever to keep it. But mine are neoprene and fine. Fit is good otherwise.
Renix AC delete pulley bearing
Crash replied to xjustinx's topic in MJ Tech: Modification and Repairs
I believe mine was a 203 xx there are different types so suffix differs. I may still have the box from mine somewhere. -
I have a 3/4 blue gauge clsuter I could let go for a price or trade. Sold my last blue gauge full cluster a while ago.
Get a matching tcase
Krustyballer Fabrications
Crash replied to shelbyluvv's topic in Vendors- members making products for MJs
Most likely.- 197 replies
- hitch
- hitch plates
(and 10 more)
Tagged with:
Upgraded Battery Cables!
Crash replied to MeanLemons's topic in Vendors- members making products for MJs
Got my cables today. They look solid! Thank you. -
I have the same lights that I plan on putting on the MJ and possibly XJ. They look nice.
If all else fails, use those built in led bolts for your lights.
If the vehicle in question has ABS, I would consider walking away, or plan on swapping in vac booster/master cyl setup.
XJ to MJ transfer case question
Crash replied to lcoutback's topic in MJ Tech: Modification and Repairs
2WD AW4 is different than 4WD. You should be able to swap the donor AW4/tcase though. Gauges will swap. You will need CTS at rear of head for temp gauge to work, and oil pressure sending unit from donor vehicle for oil gauge to work. Basically, plug n pray. -
Any one use Bardhal fus1on?
Crash replied to omega_rugal's topic in MJ Tech: Modification and Repairs
Never heard of or used it. Amsoil AMO has zddp in it. And Valvoline VR1 does as well. -
4.10 should be fine. I have 32's with 3.73 in my 88 MJ 4.0/pukegoat and it does decent (probably mostly with the F8.8 lsd) But wish I had more. When I bought the truck it had a heavy utility bed, 235/75's and 4.56's Even without the utility after I swapped a regular bed on it, it was more peppy and I liked that. I may go 4.56 for the fact that I will probably end up with 33/35's in the future. My 4wd swap is priority right meow though. I also have an XJ with 32's on it (ran 31's prior to JK wheel swap) and it has 4.10 gears with an auto and it's very decent. I say, if you find a good priced pair of 3.55 geared axles to bolt in do that and see how you like it. Otherwise, go 4.10 unless you really think you will go to a larger tire sooner than later.
My understanding as that the current Ecodiesel was supposed to be an option.
I would say no more than a thousand should be good.
I do like the prothanes better, as they are a progressive stop vs stock replacement. A little more Money but worth it, IMO.
Hats Are Now Available
Crash replied to cromanyak's topic in Vendors- members making products for MJs
Same here. I have a huge head and the adjustable ones just don't fit me right.That is not my specific reason, but but along the same lines as far as fit and comfort. -
You linked the 97-01 versions. Can you use them? What's the difference?The late model ones 'push in' as the apparatus is not removeable. Early models you could unscrew the whole assy. But the stop can still be removed. I use prothane bumps.
Cummins B3.3 Powered Mj Build!
Crash replied to krustyballer16's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Make some bed rail protectors, I'd buy some.- 299 replies
- diesel
- cummins 3.3l
(and 1 more)
Tagged with:
Front end 87' sportruck
Crash replied to Kyleinreallife's topic in MJ Tech: Modification and Repairs
1-tons have extra complications. You'd want to be running at least 37" tires for clearance. I partially wish I had ordered 40s rather than 37s with my 1-ton XJ build, just for clearance. Plus they're heavy axles, so you will need to do some reinforcements on the chassis/suspension, spend more money on shocks, steering, etc. Weight in general is your enemy. Part of the reason the XJ/MJ generally wheeled circles around everything else in their day was because they were lighter to start with, especially given that they were longer than many of the comparable Jeeps; it makes a huge difference performance wise being 4000lbs with 35" tires vs 5000lbs with 35" tires. But yes, building a D44 vs a 60... 60 almost every day, just as long as you've got the tires to justify it. I already told him I think JK axles might be a good option. Would they be? I dunno. He hasn't said what size tires he wants, or if/how he plans to wheel it. Did you shave the axles for more clearance? Done properly you can have just as much clearance as a 44. David Bricker on Naxja has a narrowed D60 that has been shaved and has as much if not slightly more clearance than the original D44. I do understand the weight to a point. But aside from that the axles are stronger and you could drive into/over rocks if you choose to do so. I'm picking up a D60 FF rear for cheap, probably what I will run in my MJ eventually when I find another full width front to match.
