Crash
Everything posted by Crash
  1. Auto TPS will work for manual. I forget if it is over here or NAxJA, but someone found a TPS from an 80's GM vehicle that usually only costs 25$ or less. Just need to swap pins in connector or make a harness.
  2. My renix MJ came from factory without AC so it has stock delete bracket. I also have a renix XJ that I swapped in stock delete bracket from AC, since AC did not work. Since easier to find, you could swap a HO bracket and AC delete bracket.
  3. If yoh have a speaker bar, try it. I have one I was going to put in my XJ, but I might toss it in the MJ.
  4. I may have another 4x4 emblem, and maybe Comanche ones. I'll look in my pile of parts soon. When it isn't raining of course.
  5. Use OE temp stat.
  6. Same here, assumed there was no light because mine isn't illuminated at all. I'd love to see a how-to on replacing itWhen I bought my XJ the hvac was not backlit. When I swapped cluster I pulled things apart and notcied that the connector had come out of it's home. Bulb lit up, but it was stuck behind panel. Not to say that others aren't burned out. But, in mine it was apparent people tinkered and fubar'd dash wiring and such for some reason.
  7. Unfortunately, without modding HO manifold for EGR no others will fit. Otherwise, plug n pray with a little massaging of intake manifold to bolt in. You should be able to find a manifold on ebay or other for a reasonable price. If you don't, I might be able to part with my spare new renix manifold for the right price.
  8. Are you ordering custom hose, depending on lift, can pick up off the shelf parts for a fraction of the cost.
  9. I think he is running a JK 44
  10. Fronts are same as XJ.
  11. I believe GordoSmasho on naxja installed a F150 8.8 in his XJ.
  12. It could also be as simple as the vac line being disconnected from the axle
  13. New apparatus to use to make stuff.
  14. I used to be all for FedEx and against the rest. UPS has served me well. I guess location and knuckleheads working at said locations can vary. Package handlers get paid decent for the amount of work being done.
  15. JK rubi (red) s ocks are more firm than the black ones.
  16. I may have 1 or 2,
  17. I just used a grinder to grind down the intake manifold enough to fit.
  18. Size as stated, least expensive will be amazon or ebay.
  19. If you are talking about knuckles, the later model one piece knuckles can be bolted in. You use associated hubs, brakes, calipers etc.
  20. There is a chart for recommended lengths somewhere. But non-adj LCA usually 16" and stock length for uppers. I definitely recommend at least one pair of adjustables.
  21. I was using TT on my phone, and thought their other kit was different.
  22. Ruffstuff makes a kit
  23. So..... I'm still looking for a good part number for an A/C delete pulley. Pulley itself or the whole 'delete assy'?
