Crash
Everything posted by Crash
  1. Pull the spare packs apart. Cut off most of the eye on the main leaf. You will probably use the main and another leaf or 2 with your current leaf pack. You need a longer center pin, longer U bolts. And shocks. I just used 3/8 allen head bolts for center pin. May need to slightly drill out hole in spring perch.
  2. Poly performance
  3. I have the renix era gm single side lock cyl in my late model doors. May need a shim or a different holding clip if cyl is loose? But mine look as if they havent been changed
  4. With KOEO.. When you press your horn 'button' do you hear a click? If so, then as stated check condition of horns.
  5. Doubt it, but a good local shop with a mandrel bender should be able to make one.
  6. I may still have my mini console.
  7. You old lock cyl will work in new doors
  8. I use a 34/78. Which is dual terminal. Useful for addon accessibility. It's actually 800 cca and 1000 ca. You can even see that in your pic FYI.
  9. If you can get another MJ or S10 pack. You can make a decent bastard pack
  10. Not much to update. I enjoy DD'ing my MJ. Still 2WD, since trans went out in my XJ. Priorities.. Anyways my gf and some friend enjoy pumpkin carving. Didn't know what to create so I found this template online. I just looked at the pic and winged it.
  11. You guys are backwards TJ on XJ is -1". So 4" will net 3". ZJ is +1.
  12. Motorcraft has their Premium Flat beam style blades that are 'universal' they list for 13.98 each.
  13. Dirtboundoffroad.com
  14. Blue loctite should be satisfactory.
  15. Well, considering the AW4 in our XJ/MJ is a very similar variant to the auto that Toyota used in their TT Supra's, rebuilt (maybe even stock pending condition) should handle just fine. Bellhousing/flexplate adapter would be the biggest issue.
  16. Pick a color, other than white to paint your truck. I personally like orange, so more than likely that is what my MJ will be eventually. I also like desert sand, which is more than likely what my XJ will be. As far as factory colors, I like the PG8 "Forest green" that my current fenders and header panel are on my XJ. Not a huge fan of white, silver, or red. A gunmetal, graphite, or darker grey-ish color would look nice.
  17. Hellcreek leafs in your flavor of choice combo with extended shackle. I wouldn't run anything lower quality than RE in the front. That leaves many options though. The RE 4.5 coils can be had on amazon for about 85-90 to your door. For anything above 3" I recommend better than factory control arms up front. 4.5 or more, definitely consider drop brackets. Or long arms.
  18. For those that "heard" that door lock cyl do not swap between early and late model.. false! I have late model XJ doors on my MJ, that have the factory single-sided GM key lock cyl. Since most of the vehicles I have owned have had 2 separate keys, I do not mind much. But, a single same-style key would be nice. I have a new complete set of matching lock cyl to swap into my XJ. Pass. side door has always been missing the lock cyl since I have owned it. Maybe, when I get to the point of swapping them I will see if I can key them the same as my ign. key.
  19. Crash
    Am I being cheap?
    I guess, pending condition and what other money you need to throw at it. If you can find a complete HP30 geared accordingly isn't turrable.
  20. Installed my DBO stubby bumper w/ receiver, and Nates4x4 steering box brace. https://goo.gl/photos/Hhkt6NjA5w7pt4iz8 https://goo.gl/photos/hVWVjxC6xLtW22D57 What a difference it makes, running an aftermarket brace vs the stock POS when it comes to bolting the box back up.
  21. Also, making sure that your MJ load sensing valve is adjusted/working properly will help. IIRC, MJ's did not come with a prop valve. I run an Exploder F8.8, no other change to brakes yet. Works good.
  22. IIRC, there are only 8 mounts, fuel tank and fuel filler.
  23. Haven't been able to do much recently. But I am midway in process of designing an HO manifold to Renix TB adapter.
  24. If you are "restoring" and going "all original", it makes sense to want to run the POS stock linkage. On the other hand, if you want something that works for a reasonable price then the boostwerks.com linkage makes WAY more sense. I'm sure whomever the future owner may be will appreciate it more than you think. Both? I'm not sure what you mean.
  25. Are you actually restoring it, or fixing it up?
