Crash
Everything posted by Crash
You can use the front axle shafts as spares if they are in decent shape. Drive shafts, at least the front may work or you co ld sell it to someone who needs a certain length shaft
Picked up 2 sets of these from the memeber at CF that cruiser recommended. I'll probably toss a set in my XJ first and see how they work in comparison to the 703's I have the Ford 5.0 injectors in my MJ currently which do well. I average 18.5 mpg in my daily commute when driving my MJ. I get 29 in my hooptie.
I wouldn't install anything larger than 30's with stock gears.
FWIW. Unless you are set on Long arms, especially since you already have adjustable arms, find a good deal on CAD brackets. I do not regret having mid-arm suspension on my XJ, but I got a great deal on my adjustable CA's and RE CAD brackets that I have on my MJ. My XJ is about 4" lift and my MJ is about 3" max. I would say that they ride similar. Springs/shocks are different on both. Also, what 4.0L do you have under the hood that the alt is up top and the AC compressor is on the driver side? WJ?
I believe 831xj over at naxja did a custom "lower" lift UBE with an 8.8. Any kits are going to get you above that, but with welding ability and such one could do it. basically you just need enough "height" to clear leaf spring center pin apparatus.
Krustyballer Fabrications
Crash replied to shelbyluvv's topic in Vendors- members making products for MJs
Definitely interested in TL housings. Either of the "discounted parts" available?- 199 replies
- hitch
- hitch plates
(and 10 more)
Tagged with:
I have BD rubber mounts in my XJ and SFR mounts in my MJ. SFR uses larger bushings so there is less vibe.
You can but reman zero mile ax15 for about 700 on ebay.
For what it's worth. I installed a new 100a alt from csk/now 'oreilly auto parts' close to 9 years ago in my XJ and it is just fine to date. Even reman are inexpensive enough to go that route.
Gas tank bolts sending unit 87-90 tach cluster 97 shift boot WTB
Crash replied to 1989 comanche mj's topic in Wanted
I believe they are j-bolts. Could probably use the part store 'battery hold down' bolts. Morris4x4 has inexpensive boots -
My new $ 500 DD, Shelby Should help aide in the conversion process and saving coin on fuel and manitenance.
comanche overheating at highway speeds
Crash replied to Newton's topic in MJ Tech: Modification and Repairs
In this situation usually means mech fan clutch is failing/failed. -
What year clusters interchange?
Crash replied to 1989 comanche mj's topic in MJ Tech: Modification and Repairs
Dummy gauge or 3/4 gauge? -
1989 longbed looking for a lift
Crash replied to Rhinojeeps's topic in Member Projects: Your Comanches
For 32's you don't need any more than 3" if you are willing to bumpstop and trim the front fenders a bit. Hell Creek makes lift leafes for our MJ's. General springs makes some MT leafs. I have about 3" lift. ZJ Upcountry coils and additional isolator up front, MJ bastard pack + longer shackles in the rear. For anything above 3-3.5 " lift I recommend CAD brackets -
I've been running some QS 20w-50 that I found for 1.35/qt . MJ leaks like most Jeepds so it helps a bit. My XJ doesn't leak oil anymore since trans swap/rms/oil pan gasket replacement
I'd go aftermarket, fixed are fine but adj. is better. Otherwise if you can find a decent pair of WJ lowers, they only need a small amount of work to fit.
Genssi 80W CREE LED White 1156 Reverse Lights
Crash replied to HOrnbrod's topic in MJ Tech: Modification and Repairs
I think I'll pick some up for my XJ. My MJ b/u lights don't work so I'm not going to bother. I have some pods on a switch if I need to see. -
Boostwerks Transfer Case Linkage Problems
Crash replied to JeepFanactic's topic in MJ Tech: Modification and Repairs
I will most likely go with boostwerks setup for my XJ and my MJ. But, I have been thinking about buying some stainless rod and cutting lh/rh threads on it to be able to adjust it without removing a side. -
Will theses wheels fit a Jeep comanche
Crash replied to ComancheLee's topic in MJ Tech: Modification and Repairs
Using an impact to snug them one is not a big deal. A torque stick @ the correct rating would be acceptable, but torque wrench should be used. -
Any pointers to a 3.4 engine swap
Crash replied to SavagePanda's topic in MJ Tech: Modification and Repairs
Sell 3.4 and buy a 4.0L or LS-based V8 motor is my recommendation. Seems like is as much work as other swaps I have mentioned. Since it sounds like swapping parts from a heep 2.8 is not an option. -
I recommend Synergy adapters , but the other ones are good too. If you look in my thread I have the same wheels on my and Ï have them on my XJ as well -
X2
Alternator or Something else.... '89 Renix
Crash replied to Archaeor's topic in MJ Tech: Modification and Repairs
Confirm charging voltage with a DVOM. If 13-14, then wire/ICP issue. -
I've only had LWB, but wouldn't mind owning a SWB. I DD mine and enjoy it. Gets better mileage than my XJ, and it's a manual which I also enjoy driving more. I've not slept in the bed yet, but being 6'2 the LWB I can fit front to back comfortably and not have to lay at an angle or with tailgate down. With good protection I see the LWB vs SWB a non-issue for wheeling.
