CRM1988
1 Follower
    Charlestown,IN
  • Interests
    Camping,Fishing,Traveling
Contact Methods
  • Yahoo
    murphychar112
CRM1988's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. What parts are required for a internal and external change over on a 97 ax15?
  2. It's grinding with the clutch out while coasting, I can push the clutch in and it will quit. It is starting to pop out of gear also. Yes the BA has been swapped out for the AX.
  3. 88 MJ 4.0, ax15 transmission. When driving and let of the gas I’m getting a grinding noise but if I get back on the gas it goes away. Really confused right now.
  4. CRM1988
    Interior
    ISO Burgundy buckets and center console or grey buckets
  5. Where could a person find parts for the window wings as in latch to hold shut and gaskets? Or a way to keep them from leaking.
  6. I have a 88 MJ that the electric fan will not come on. Wired it direct so I know it works but it will not work otherwise. Is there a relay or fuse to it somewhere?
  7. Thanks for the input
  8. I am looking at putting a 2" lift on my stock 88 pucks in the front and add a leaf in the rear my question is can I put 31x10.50x15 on my stock rims and run them without having to do any cutting on my truck?
  9. Where is a good place to buy the seals that goes around the window wings that open and shut on the doors and the outside weather stripping on the roll down windows?
  10. I went with add a leaf from skyjacker $100 and spacer for the coil springs up front.
  11. Thanks for the info
  12. So how can you tell whether the thrust bearing is bad?
  13. I know there is probably a thread somewhere, but after 2 belts a belt tensioner pulley and lots of squeaks and chirps I noticed today that the harmonic balancer has a wobble to it could this be the problem I am having? How hard is it to replace this and any tips and tricks to doing this replacement would be greatly appreciated.
  14. Do you remember the part# or the name of the belt it shows about 8 different ones on there website.
  15. So the new $42 belt took care of the noise?
