895XJ
1 Follower
    Driscoll, NoDak
  • Interests
    Jeeps, duh.
1096 profile views
895XJ's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. First off I apologize if this is not in the right sub forum but on the matter of this lights, omix ada gave me a bit of optimism in their response when asked about the matter Sent from my XT1635-02 using Tapatalk
  2. It may be a long shot here but I am trying to gather parts for a 97+ swap. I am looking for an extended idle switch, four bezel switch panel, black door panels with woodgrain trim and black infinity tweeters. Any leads on these parts are appreciated, thank you! Sent from my XT1635-02 using Tapatalk
  3. I have, what I would rate, an excellent condition one if you're still looking Sent from my XT1635-02 using Tapatalk
  4. I have one if you're still looking! Sent from my XT1635-02 using Tapatalk
  5. I'm looking for pictures of a 95-96 XJ steering column, with column shift out of a police XJ. Does anyone have these photos? Not looking for 94 and down, oddly specific I know.
  6. I'll let the pictures speak for themselves. Anyone who is new to this, I hit a deer going want warp speed (80-85) Sent from my XT1635-02 using Tapatalk
  7. I've got one. Body or hood side? Sent from my XT1635-02 using Tapatalk
  8. It's best to keep your scanner in the vehicle and pull the code while it's still up In my experience, a CPS will only throw a code if it's causing a misfire, not when it dies completely Sent from my XT1635-02 using Tapatalk
  9. Just to give everyone an idea of damage no related to the body. Cracked harmonic balancer Cracked timing cover Pushed mech fan shaft back 3/4 inches Ruined water pump Bent fan and water pump pulleys Cracked battery and sprayed acid all over all my nice sand blasted and clear coated aluminium​ parts Sent from my XT1635-02 using Tapatalk
  10. Not a write up just sharing some pics from the repair If anyone knows where a pair of pioneer fenders that match my MJ are, let me know, I'd love to make this thing match Sent from my XT1635-02 using Tapatalk
  11. My yard is my JY. I've got four parts cherokees
  12. That's an awesome video I didn't know existed, definitely going to try this myself now! Hood could be saveable but from a PO hitting a deer and replacing it with one that's not oem (very thin), its getting replaced
  13. Hit a deer early this morning on interstate, gonna try to fix it, thoughts? Sent from my XT1635-02 using Tapatalk
  14. I've separated the lens and housing and no luck removing it from the inside, oh well, they'll just have to be "b grade" for the rest of their useful life
  15. I need help restoring my MJ tail lights, has anyone had success removing this "rust spot" from the backup lens? Sent from my XT1635-02 using Tapatalk
