88towmanche
1 Follower
    Seattle metro
88towmanche's Achievements
Comanche Aficionado
Comanche Aficionado (4/11)
  1. Yep - the Astro was chevy and used the orange DEX-COOL The way I remember it working was you pour the bottle into the radiator and continue normal driving and just check the exhaust with a blacklight flashlight (don't remember if there was a set amount of miles that had to be driven or what) but eventually I could see residue on the tail pipe using that little flashlight showing that at least some coolant was coming through the exhaust. The whole test cost like $20 with the flashlight and gave me some answers...I bought more of the dye fluid and then started trying different head gasket in a can to see if I could stop or slow down the leak...had some success, I'd pour a can of Kseal or something in there and then check with the dye for a while to see if there was still coolant coming through - sometimes it would be clear for thousands of miles, other times wouldn't get that many - told the guy I sold it to all about it and gave him the flashlight. That old Astro never flinched and I abused it with heavy loads long after I notice the problem...didn't consume any oil or overheat and I went from like a pint of coolant loss every 1000 miles to maybe a pint every 5000
  2. Yeah I think Kseal was one of the ones I used...but keep in mind I didn't care on that old Astro was just looking to buy time (and did) - same as you saw a lot of positive reviews and figured had nothing to lose...far as I know it did no damage and the van still cruised along until I sold...got at least 20k out of it after the problem popped up
  3. Think it was this - you have to buy the blacklight flashlight also
  4. Could be going through intake and out exhaust - there's a dye kit on Amazon you can check that pretty easy - if it was substantial, never mind it would be obvious, but I had it happen on a v6 Astro van - engine survived another 20k miles I had it and was upfront with the buyer when I sold it. Went through maybe a pint every 1000 miles or so...I slowed it down periodically with magic sauce from the auto parts store - engine block in a can sort of thing.
  5. I didn't see it mentioned here but I had a sudden massive oil leak on a Cherokee ('88, Renix, 4.0) and it was a failed sending unit - cheap and easy.
  6. Got spacers on mine - think maybe 1-1/2...have to look it up. Technically there is a puck n shackle 2" lift with but the old saggy leafs & springs it's probably just a bit above factory height.
  7. I used these off of Amazon - no complaints
  8. Chinese seatbelt:
  9. The two door XJ seatbelt is longer/shorter than the MJ - can't remember exact dimensions but it was a little close for comfort so on mine measured the old belt and bought one that was as close as possible - Chinesium unit off of Amazon. On the bench seat the china unit was almost too short on the female side and had to modify the bracket for the retractor to bolt up properly and still not interfere with trim panel. I have a 2 door Cherokee will have to look at that again to see the difference but think the retractor mount is on the floor on the Cherokee & on the MJ it's about half way down the pillar.
  10. new 410 44 is in place - new ubolts & hardware, working on airbags & waiting on cut down driveshaft.
  11. Used fork extensions on the Hyster to reach up under there and pull the old axle out while truck is on the lift.
  12. Still hacking away at this - bending and flaring brake lines Using the nickel-copper tubing makes it easier to form good flares
  13. Had a 69 Nova that was Butternut yellow - similar color
  14. I got a set from Krusty specifically made for long bed.
  15. More progress.... Got the cover (new) on the diff - did a quick tape/spray job and clear coated the whole thing. Used a couple of studs to stand off the LSV bracket (thanks to The86manche for the bracket) getting the brake lines sorted - have some cunifer line and ss gravel guards to diy replace the hard lines on the axles....but the ones on the '88 are pretty clean so might just use those. Waiting on a few more parts - have an airbag kit plan to install but with the shackle lift need spacers for the airbags - those are on the way...
