512tr
Location
Norway
512tr's Achievements
Comanche Aficionado (4/11)
Jeep variable assist steering pump.
512tr replied to 512tr's topic in MJ Tech: Modification and Repairs
I think this SPS (Speed Proportional Steering) is a rare thing on older Jeeps, as far as I have found out it was only on 1996 ZJ. Probably not the best system /too expensive, since they didn’t continue using it in the coming years. As far as I have figured out the system consists of a solenoid valve on the pump (regulating the pump flow), a standalone control module, a steering wheel sensor and input from the vehicle speed sensor. The reason I’m curious is that I have a part-out ZJ with this steering pump, and it bolts straight on to the +99 intake without any modifications. I think it works as an ordinary pump if the electrical system is not connected/fails (full power assists all the time). Time will tell if I will us it and get it to work. 😊 -
I think you still could do the CAD delete and use the vacuum lines to only operate the 4WD vacuum switch and have the 4WD light working when the TC is in 4WD. If you feel the need for it, don’t let it be a dream.😊 It’s quick and easy to realize in few minutes, just cut the yellow line and install a small valve. If you want it inside the cab just extend both lines to the cab and connect the valve. You could use a small gas valve or as simple as an aquarium air control valve (as I did). I did this on my YJ a long time ago, to ease maneuver with a trailer in a very tight space.
Did some simple bump stops from a piece of 2” oak bench plate, and a HD rubber mat. I hope the pictures are self-explanatory. 😊
Need a second opinion on this color.
I don’t have any rear window to reinstall 😊 Luckily the rear window has a simple form and doesn’t require any shape on the window to fit, so I plan to use a sheet of best quality Polycarbonate or equal. Just after I got the truck, I replaced the old cracked window with simple Plexi glass, and it served well all these years…..then, I just cut it with a jigsaw, glued it and put some screws. What I haven’t solved yet is how to make a sliding window, any ideas? Have been looking on the internet in the boating and caravan world to find ideas for making a sliding window and trim around the window. Window trim alternative Fender Flares… 18 years ago a bought Bushwacker flares, they are still in the original box😊 -
The gas tank is 2 mm 316 stainless steel, tig welded, it's approximate 64 liters (17 gallons) I've refurbished the tank and made new cross members, don't want to bolt anything to the bed. Have some vague plans to make a second bed, easy on/off…time will tell😊 You observe details 😊 I think I have 11-12 sets of Jeep rims, near all cars in Norway do have 2-wheel sets, summer, and stud tires for the winter, at least in the north where I’m living…nothing beats studs on icy roads. The wheel in the latest pictures is just temporary, it’s the 17” summer wheels for my ZJ, don’t know yet what rims I will end up with, do have some to choose from, including Jeep turbines and some 15x10 rims. -
Thanks, do have a picture with that big wheel loader wheel on the bed...but sadly I can't find it now. -
That's good, you are a patriot😊
Yes, that’s the same truck as I’m working on, and yes it's black (dark grey) paint. Older picture. It is 20 years since I bought it, it has been a very reliable and good truck, but has been neglected for years. From the pictures you can see that it was quite shabby and needed treatment and care😊. Pictures taken the day I started dismantling. -
Some years ago I was on a work trip in Holland, spotted this MJ in a small Dutch town. Looks like a company truck. I think this is the only Comanche I have seen "live" except for my own.😊
Thanks for all input. I have decided to keep that color in the engine bay, the truck itself will not be painted before the spring so I have time to figure out what to do.😊 -
If you still have the D30 CAD and feel the need for 2WD in low range, you could install a valve on the vacuum line that engages the CAD. With the valve closed (no vacuum) there will be no traction on the front wheels. That clunky factory t-case shift setup could be improved by using this Transfer Case Linkage Kit, I just got 3 kits, for my MJ and other 2 Jeeps.
Thanks for all replies. I chose this color inspired by the color scheme on the 2016 Comanche concept car. In general, I find it very difficult to choose color. I finished a motorcycle project last summer and ended up leaving it unpainted, another bike I built I painted twice, the last time with expensive chameleon paint...after 14 days I couldn't stand the paint and wrapped the whole bike in satin black and carbon. ...now I'm reasonable happy with both. -
Beautiful, has to be one of the best looking MJ's out there.
