Crash
Everything posted by Crash
  1. I think they meant mechanical speedo vs elect. But you are correct.
  2. My MJ has the GM weatherpack style plug, I'm considering finding another piece of harness or buying pigtails to 'tee' into the circuit for trailer wiring. Would make removing or changing it a cleaner install.
  3. The braces for cad brackets won't work. The only exception is the RRO brackets, they make an MJ specific brace that comes with theirs. I have not heard many good reviews of that company, and I know Bo detests them. FWIW, of the people I know that receided product from RRO the quality looked decent. I didn't want to take the risk at the time and the RE brackets are less expensive. I run the RE kit as I posted without braces. One of the better things about the MJ vs XJ is the beefier body side LCA brackets. As far as TB/bracket go. If you do not already have a decent double shear TB I would get one. The RE setup is nice, however the price for the TB setup seems a bit much in comparison to some others. The bracket itself is reasonably priced IMO. Lots of people run IRO setup with zero issues. I have the RE setup with cross brace(no complaints)on my XJ because I got it used for a good price. I also have a spare 1660hd in good shape if you wanted to make a deal on that and buy their bracket. On My MJ I have the synergy trackbar mount and brace with some no name TB. That TB will be changing when I do my axle swap but keeping the existing mount.
  4. For the money, I would definitely consider 60's, 60/14b, or something similar. Especially since you can fab. Typically the amount of money it takes to properly build 44's (exception being stock xj/mj/tj), You start with much stronger axles using 60's etc.
  5. Most of them are basically the same. I picked up this set. Rubicon Express RE9900 Control Arm Drop Bracket for Jeep XJ https://www.amazon.com/dp/B006GJKBXK/ref=cm_sw_r_cp_apa_GiGlzbNPGNEVP Looks like the price is slighty higher at 182$. But free ship.
  6. I believe that the apparatus can be installed 4 ways. Try to place inside by hand, gear only and see which way the cover should be installed.
  7. Wish there were flex/pro fit available. I don't wear adjustable hats anymore.
  8. Shipping cost to 93444? Or 93401 or 93420 to business if cheaper? Thanks.
  9. What do I need to do to get this price? I work til about 2130 PDT, but can send money any time after that. You can PM me any info necessary.
  10. Not usually that expensive for the brackets. Unless you buy a kit with arms. I bought my RE drop brakets on amazon for about 160$ IIRC.
  11. I run ZJ park brake cables on my 8.8.
  12. With as much lift as you will have, I recommend running control arm drop brackets with short arms.
  13. If you weren't on the wrong coast I would offer my parts MJ rolling chassis.
  14. I used the spring plate/shock mounts from the exploder donor vehicle. Works fine.
  15. Dark Blue @ 1:15 silver MJ.
  16. Are you talking dips tick tube. Or where the cooler line connects to the trans?
  17. For what it's worth. I have mid arm 3 link on my xj, and cad brackets and adjustable arms on my mj. They both ride nicer than stock. The brackets put your arms at close to the same angle as they are stock. I also paid about the same for both setups. Otherwise I may have gone mid/long arms again.
  18. I think, for what you want, drop brackets are going to be just fine paired with some decent/nice aftermarket control arms.
  19. Neither is a Comanche body with a Chevy engine in it. Neither is a Comanche body with a Chevy engine in it. According to the registration it is. :P Neither is a Comanche body with a Chevy engine in it. So all the 2.8L Comanches are fakes?AMC clearly did anything they wanted/could. And yes, some early ones had GM engines in them. Just because you like or dislike something does not make it good or bad. LSx based engines, for the most part, are reliable and produce really decent amount of power. Also, there are plenty options around. To reliably build a 4.0 based stroker to run on pump gas, high power, and reliable is going to cost quite a bit of cash. Not to say that an LSx swap on a budget is not a difficult task. However, most are run on 87/equivalent low octane with high power output. But any of these swaps, with a proper tune, will run on any grade of fuel you desire. From an 'I need my vehicle to pass inspection' POV, a 4.0 replacement or stroker makes more sense as no one knows the difference. I do appreciate and respect my 4.0L, but depending on specific application and use an LSx is a very valid option in my eyes.
  20. If you can, get a decent set of late model XJ 4dr seals. They are thicker. I have some in my MJ and XJ
  21. or they can just swap to another truck native V8 entirely... Another truck isn't an MJ though..
  22. Did you buy the Crown one or one of the other 'inexpensive' ones? Either way, a good deal considering. Definitely on my list of things to upgrade, but 4WD swap comes first.
