Crash
Everything posted by Crash
  1. I have ZJ park brake cables for my 8.8 and some lift.
  2. What trans are you running?
  3. Adding a piece of flex pipe in the crossover of downpipe will help prevent cracks/failures Sent from my SM-N910T using Tapatalk
  4. No. The BA 10/5 was phased out early in the 1989 model year. Most '89s had the AX-15, and all '90s had the AX-15. Been corrected, but I believe early AX15 are 21-spline. Would need to confirm. Sent from my SM-N910T using Tapatalk
  5. 90XJ could have either trans. You would need to confirm Sent from my SM-N910T using Tapatalk
  6. For Wilwood?Unless they recommend or specify a specific UB, all of the BB kits I know of use the 00+ UB. Sent from my SM-N910T using Tapatalk
  7. Snapon mt2500 with correct cable and carts. Otherwise, IIRC old_man over on naxja is making one. Not sure of ETA. Sent from my SM-N910T using Tapatalk
  8. A ZJ front shaft may work. Sent from my SM-N910T using Tapatalk
  9. On naxja I believe there is a write up with PN's for seals and such. Sent from my SM-N910T using Tapatalk
  10. IIRC, using the 00+ UB is what you need to do.
  11. When are you gonna sell bolt-in taillight boxes? Haha if I did not already have steering box spacers it sounds like a good deal. I also kinda want LWB sliders but I am planning some some frame stiffeners first which slight changes the length that mounts to the frame. Sent from my SM-N910T using Tapatalk
  12. If you want to level, do it. But I recommend an aftermarket quality TB/mount.
  13. I'll have to check out BG44K myself. I've never heard of it. As for the Seafoam spray, I've only found it at Walmart but I recon Amazon has it. The parts stores don't seem to have it. It's just the regular formula of Seafoam but in aerosol form. It comes with a really long straw to feed into the intake tube. You can do the same thing by SLOWLY pouring the regular liquid Seafoam into the intake. I've also heard of people using a vacuum line from the intake stuck in the can so it sucks it out like a straw but I've got no experience with this method. Seafoam spray can be had at O'reilly, carquest/AAP, Napa etc. I usually do a half can of Berryman B-12 ( Seafoam is basically the same, just not been around as long and more expensive than B-12 ) through the brake booster line. Clean TB with TB cleaner. And use either B-12 or MMO in the tank. I have also used the BG stuff and Amsoil Pi
  14. I agree with first statement. Your last statement, however, without a plate behind to support the load sounds like a bad idea. Unless you happen to be a small/lightweight person. Full armor makes more sense. , IMO. To counter the 'doesn't like full armor' , the armor could be painted body color to be practically invisible to most.
  15. 3/4 clusters were mostly complete gauge set, minus tach. Still had a large fuel gauge. Yeah, I figured that out now. Why? Who can live without a tach?> Some people can, and it's bettr than a full set of dummy gauges.
  16. Do the YJ column that ppl swap in have tilt?
  17. 3/4 clusters were mostly complete gauge set, minus tach. Still had a large fuel gauge.
  18. My MJ has the vinyl floor cover. I have though about pulling it, bedlining the floor and using some marine-grade carpet.
  19. Apologies for OT, but I believe I have one or 2 am/fm cass decks with inop cass.
  20. 2 or 4wd? Other than that, buy a running driving XJ/MJ and swap everything necessary. Rear driveshaft will not be plug n pray if you get an XJ donor
  21. You could probably make one out of similar material. Otherwise, I will be doing a 4wd swap on my MJ soon and if it is intact can send you the one from my factory pukegoat
  22. If CEL is on, failiure is immenent (sp?). Since not OBD2, if the CEL is not illuminated longer than it's supposed to be upon starting and does not come on at all during test then it would be fine.
  23. I know there are a few people on naxja that have LS swaps that have done custom gauges.
  24. I would just go black belts to go with that. Or dark grey even
  25. I used WJ belts out of a parts vehicle I had.
