offthepavement
    land between the lakes
  • Interests
    finding more information on mine and others mj-s
1625 profile views
offthepavement's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. Hi all.been awhile.hope all is well.so i changed the oil pan plug out with a magnetic plug but the thing leaks so not the right one.didnt do the ol take part off read whats on there get same part ideal haha old plug thrown away.would any one be kind enough and smart enough to enlightenment me on the exact plug i need for a 1989 comanche 6 cyl please and thanku
  2. Oh and it wasnt seeping from any rust hole.it was just coming out of shiney metal.i sanded the rust spots down alittle though and it showed metal but where it was seeping there wasnt any rust even remotely by it so idk what thats about but i patched it and its still holding Sent from my LG-V410 using Tapatalk
  3. Well i tried the steam engine method now it won't turn on haha jk.i did do it ever so slowly not sure if it worked or not yet.I'm letting the truck cool down.hopefully if it didnt help hopefully it didnt hurt it.well see tomorrow Sent from my LG-V410 using Tapatalk
  4. Any suggestions on how to clean out the carbonation in the engine and whats thats places ??? Sent from my LG-V410 using Tapatalk
  5. Patched it problem solved for now..it will be the next guys problem after i sell it [emoji6] hahahahaha aahhhhh hahahahahahaaa [emoji1] Sent from my LG-V410 using Tapatalk
  6. Welp after putting in a new fuel pump it ran good for couple weeks now i have gas seeping out one of the few rust spots on the bottom of tank [emoji1] keeping it interesting for sure Sent from my LG-V410 using Tapatalk
  7. This is fun please share more.torque bar that sucker after tapping it.don't listen to me..it will most likely break off deeper in Sent from my LG-V410 using Tapatalk
  8. Hey thankyou Sent from my LG-V410 using Tapatalk
  9. Hey all!so I'm trying to set the timing on the distributor due the comanche stopping hard when turning key off.I'm not exactly sure how to do it on my 1989 4.0 manual.can i just loosen the bolts and turn it alittle until it sounds right??? Sent from my LG-V410 using Tapatalk
  10. Update of sorts.so after cleaning the throttle body i now can accelerate up steep hills in fifth gear which is what i was aiming for..wooo!haha.got new shock absorbers on.just cheap ones.bout to put in new fuel pump.hopefully that helps with the hard 3 crank start.I'm also switching to the 2.50 gallon unleaded non ethanol gas cause i guess jeeps back then ran on non ethanol additive.ten percent ethonal is 1.90 gallon haha.still trying to figure out why it pulls to the right.i havnt put much effort into that.all in all it runs good. Sent from my LG-V410 using Tapatalk
  11. hey thank u so much Sent from my LG-V410 using Tapatalk
  12. like the hoses are for ccv or pcv whichever right haha ccv has a way smaller opening goinh into valve cover but hey I'm no mechanic and parts store they seem to think only pcv system exist.anywhat...they connect to let me see on page 2300 of manual hmmmm yup not sure what part to buy and replace.I'm thinking maybe its stuck open whatever valve that is..maybe the crank case valve thingy part number something haha gotta call jeep tomorrow for sure Sent from my LG-V410 using Tapatalk
  13. the l shaped hose going into the air box is whats leaking.second pic is where it connects from air box.what exactly is this and the valves? in the second pic? Sent from my LG-V410 using Tapatalk
