Kalal92
1140 profile views
Kalal92's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. Video has description Sent from my iPhone using Tapatalk
  2. Took the Comanche out for a quick drive after changing the hoses, if you can see and hear in the video after going into neutral and turning almost dies hitting pedal and doesn’t want to go. She starts up every time with no problem just doesn’t want to stay running without a high rpm Sent from my iPhone using Tapatalk
  3. Do you know what the rear piece is called? Sent from my iPhone using Tapatalk
  4. Sorry didn’t mean to split that Sent from my iPhone using Tapatalk
  5. I was looking online and seen some 2.5s with two hoses for the PCV (in and out) I didn’t know this because when I first got her it had a crossmember to each pcv ports going straight to the throttlebody it was like that and so I didn’t question it. If this is right is the front end and the back out or vice versa the only thing I could find is the 4.0 unless it’s the same? Sent from my iPhone using Tapatalk
  6. Sent from my iPhone using Tapatalk
  7. Low idle or goes up-and-down fine while driving but after coming to a stop or neutral will drop again or die. Sent from my iPhone using Tapatalk
  8. you tried ratchet extenders? Works on my 86 2.5 Sent from my iPhone using Tapatalk
  9. Got home went to the garage started to record a video to show you and put it in gear with clutch down let off and it move forward neutral back in gear with it running and did not grind. I have a video if needed but happy it’s not grinding Sent from my iPhone using Tapatalk
  10. A little lighter and coming from the clutch area I will try what you said when I get off work Sent from my iPhone using Tapatalk
  11. I did not try to engage the clutch when it was in gear and running because the grinding I only had it running for a second Sent from my iPhone using Tapatalk
  12. No movement Sent from my iPhone using Tapatalk
  13. A light grinding sound Sent from my iPhone using Tapatalk
  14. Sent from my iPhone using Tapatalk
  15. Turned The harmonic balance to 0 and placed the plugs in Firing order. But won’t go into gear so might have another problem [emoji29] Sent from my iPhone using Tapatalk
