You sound like me many years ago. My BA10 had gone through 5 internal slave cylinders. It wasn’t getting a sixth.
There are videos on YouTube that show how to take apart and rebuild an AX15.
The presenter is”UCanDoIt2”.
H&R Block has been a good source of clients for me. I am often fixing mistakes, responding to IRS notices, or amending a return to claim a better tax position then was originally claimed on a return.
Thank you Block.
I was going say what Eagle suggested.
As for the dust shield, it is sandwiched between the engine block and the flywheel. To remove the dust shield requires removing the transmission and the flywheel.
Manual transmissions don't have inspection plates. The dust shield is a solid, single piece of metal.
You have to remove the rear bearing cap to access the RMS.
You don't have to pull the trans to change the RMS.
The RMS is a two piece seal.
You have to drop the oil pan and remove the rear main bearing cap. The lower half of the RMS is in the cap. Use a small brass punch to remove the upper half of the RMS.
Mine was doing the same thing. The vent tubes got crushed after the bed was removed and re-installed after a restoration. I dropped the tank and re-routed the lines - taping them in place to prevent movement and getting crushed again. No problems since.
I tried fitting the 97+ master cylinder. It was a while ago. I don’t think the bolts line up with the existing holes. It also sticks out farther from the fire wall.
MJKally, nice to see you found ComancheClub. I had responded to you on JF previously. (I couldn’t recommend you to CC or else JF would chastise me.)
You can find all the information I referenced on CC and more. The members here really knowledgeable and will help you with all things MJ.
Post some of your other pictures on CC. Also register your MJ in registry section.
Welcome to the addiction!
I am getting water on the passenger side during some rain storms. It appears to come through the heater vent box. I have seen videos on YouTube about leaks coming through the front cowl. The water drips through a metal seam where the sealer has dried and cracked. The videos show cutting an opening in the cowl’s metal to access the sealer seam. Then reapply caulk or RTV to seal the leak. I not sure I would want to use these extremes on my MJ.
