9
Everything posted by 87MJTIM
You have to dissect the door. Remove the interior door card. Roll the window down. Remove the vent glass frame. Remove the glass and old weather stripping. Also, it's good to replace both of the sweeps. Reverse the steps. Take pictures of the parts before removing. You can look back to see how it looked originally.
You sound like me many years ago. My BA10 had gone through 5 internal slave cylinders. It wasn’t getting a sixth. There are videos on YouTube that show how to take apart and rebuild an AX15. The presenter is”UCanDoIt2”.
Not taking new clients. I am starting to wind down operations.
I got the tailgate. Rear bumper is not bad but seized on tight. The bed is not in bad shape. Rust on the floor but the sides are good
H&R Block has been a good source of clients for me. I am often fixing mistakes, responding to IRS notices, or amending a return to claim a better tax position then was originally claimed on a return. Thank you Block.
1989 ba10/5 rear main seal
87MJTIM replied to Buffalo Man's topic in MJ Tech: Modification and Repairs
I was going say what Eagle suggested. As for the dust shield, it is sandwiched between the engine block and the flywheel. To remove the dust shield requires removing the transmission and the flywheel. -
Manual transmissions don't have inspection plates. The dust shield is a solid, single piece of metal. You have to remove the rear bearing cap to access the RMS. -
You don't have to pull the trans to change the RMS. The RMS is a two piece seal. You have to drop the oil pan and remove the rear main bearing cap. The lower half of the RMS is in the cap. Use a small brass punch to remove the upper half of the RMS. -
Is there a decent bed mat available new?
87MJTIM replied to OzarkGuy's topic in MJ Tech: Modification and Repairs
Excess pressure in fuel tank
87MJTIM replied to hgeranium's topic in MJ Tech: Modification and Repairs
Mine was doing the same thing. The vent tubes got crushed after the bed was removed and re-installed after a restoration. I dropped the tank and re-routed the lines - taping them in place to prevent movement and getting crushed again. No problems since. -
MJKally, nice to see you found ComancheClub. I had responded to you on JF previously. (I couldn’t recommend you to CC or else JF would chastise me.) You can find all the information I referenced on CC and more. The members here really knowledgeable and will help you with all things MJ. Post some of your other pictures on CC. Also register your MJ in registry section. Welcome to the addiction!
How did you do this? These are some of the YT videos I watched.
I am getting water on the passenger side during some rain storms. It appears to come through the heater vent box. I have seen videos on YouTube about leaks coming through the front cowl. The water drips through a metal seam where the sealer has dried and cracked. The videos show cutting an opening in the cowl’s metal to access the sealer seam. Then reapply caulk or RTV to seal the leak. I not sure I would want to use these extremes on my MJ.
Hang a price tag from a mirror and call it: Mini-Pearl
Novak AX-15 short throw shifter
87MJTIM replied to Eagle_SX4's topic in MJ Tech: Modification and Repairs
Speaking of sticker shock…. -
I blame "plate tectonics" to cause all the continents to shift westward.
Modified OEM Radios “Feeler”
87MJTIM replied to ghetdjc320's topic in MJ Tech: Modification and Repairs
I would be interested in bluetooth function. I have two original radios - one AMC and one Chrysler. One is a RX161 and the other is a RX170. -
Coolant Loss. Dip stick clean, and no leaks
87MJTIM replied to RG67MA's topic in MJ Tech: Modification and Repairs
I installed the felpro T-housing gasket w/o rtv on my 93 4.0 in my CJ. No leaks. -
Renix Fuel Injection Manual - missing page 59
87MJTIM replied to 87MJTIM's topic in MJ Tech: Modification and Repairs
Hopefully someone can change the link to the pdf to include the correct page. hint hint -
Since I have never seen the page before, I can only say that looks like it. -
Every download copy of the Renix FI manual is missing page 59, but has two copies of p. 58. I am sure all the downloads are from the same source. Does p. 59 have any info? Does anyone have a paper copy of the manual? Can p. 59 be uploaded to this website? Edit: p. 59 is the manual's page number, not the pdf page number.
