87MJTIM
    9
Everything posted by 87MJTIM
  1. I would, but I am away for the next week
  2. When the person says “My grandfather had one….” Then I feel old.
  3. This literally just happened today (11/11) at the gas pumps. The guy at the pump ahead of me was looking at my truck. He walked back to me an complemented me for it. He looked at the inside and said "Oh, it's a stick." He then asked if a wanted to trade mine for his Toyota Taco. I respectfully declined.
  4. You can reverse trace the PO's wiring to figure out where s/he was drawing power. If you have not yet done so, download the 88 electrical manual pdf (here). Use the cooling system setup to take yours back to factory. Our Renix engines have three (3) temp. sensors. One for the gauge/idiot light, one for the ECU, and one to turn the e-fan on/off for cooling. Figure out why the PO would wire the fan to run continuously. Was it overheating? Why? Address that problem. Was he slow wheeling it and wanted to keep it cool? Will you wheel it? You could wire a switch to turn it on/off when you want it - but this would override the factory cooling fan switch. Did a PO swap radiators to later HO versions without the temp senor hole?
  5. The pedal return will depend on the spring tension and cable tension. The rubber stop just keeps it from slamming metal to metal.
  6. Reverse lights: "A long time ago in a galaxy far, far away..." No, wait a minute. "It was twenty years ago today..." That's not it either. A while ago, the wiring for my reverse lights close to the transmission switch contacted the exhaust pipe and melted the wires. I tried using the heat shrink connectors with the small bit of solder inside. The solder did not melt very well and the connector finally separated. I discovered this when backing up one day and noticed in a window behind me that the rev. lights were not on. After multiple tests - lights, connectors at the rear, tracing back to the transmission - I determined it was my crappy soldering connectors. To fixed it and the botched soldering job, I used U-shaped copper ring connectors and heat shrink tubing. (Amazon https://www.amazon.com/Tnisesm-Terminals-shrinkable-Electricity-Automotive/dp/B0CSFDT5CS/ref=ast_sto_dp_puis?th=1) Now my reverse lights work. Cruise control: My cruise control has not worked for YEARS. I have looked everything over for years trying to determine why it wasn't working. It had me stumped. Once every year, I would try again without any luck...until now!! I want to send a thanks out to @Eaglescout526 for sending me a AM-PC-1-R tester. Also, if anyone else is have trouble with their CC, I highly recommend going to NAXJA.org. TJMotter has an excellent write up on testing the CC on a Renix MJ/XJ. Link: https://naxja.org/threads/how-to-test-repair-renix-era-cruise-control.1160060/ After performing all the recommended tests - most all repeatedly - I found two problems with my CC. First, the vacuum dump valve at the brake pedal was not pushed in all the way. The system was not holding vacuum. This one issue probably arose long ago when I had brake work done. The second issue I found was the ground wire to the engine block was frayed and not getting a good connection. I discovered this when performing one of the recommended tests for resistance on the ground wire. I had 24 Ohms when it should be 0 Ohms. (I am sure Cruiser is looking down on me saying "I told you to check and update the grounds.") Test drove it and it worked. A new problem - but a nice problem - is when I set the CC, the truck accelerates by about 7 mph above my set speed. It will hold that speed for a mile +/-, then it will gradually start to drop to the set speed. But that's a problem for another day.
  7. To follow up on Derf: the rear bolt is hard to reach. The engine tilts upward at the front. The back of the valve cover tilts under the firewall lip making it hard to get out (and especially get back in) the bolt. Somewhere I read that putting a jack under the transmission and raising the back of the engine ever-so-slightly will give additional millimeters of clearance. You are not trying to lift the engine; you just want to get a little more space between the VC and the firewall. Just my 2¢.
  8. Holy Grail - hands down. Beatles vs Stones
  9. This one popped up on Facebook https://www.facebook.com/share/1JQDedoDMV/?mibextid=wwXIfr ‘97
  10. Yes, the MAP not connected is a definite “No start.” Crank, no start.
  11. I have thought of the Renix ECU like Frosty the Snowman. Each time Frosty puts on the magic hat, he wakes up like Rip vanWinkle, not sure where he is.
  12. That doesn't sound good. I remember Jeremy had health issues then changed jobs that took a lot of his time. He had to "step away" from the radio business and his MJ. Hopefully, he is doing better and he can get back to his MJ soon. I searched on Jeff Bezos's store (Amazon) for BT adapters. I always read the negative review first for the issues and the date of the review. One that I read gave a very bad review in Aug 2025 - last month. Other reviewers gave similar comments. Does anyone have first hand experience with BT converters and would recommend a brand?
  13. Nice work. What can be done to either a RX161 or RX170? I have one of each. Can they be converted to accept BT? I have read some write ups on adding AUX by eliminating the AM receiver. Can the AUX/BT be routed thru the AM and/or the tape player?
  14. I did some searching and research on mercury switches and thought it just wouldn't stop working. I decided to re-examine the unit and clean all the contact points. I finally got continuity from the + wire in to the light socket with the unit held vertical. I have not tested it to a battery yet. The light bulb needs replacing. Age and corrosion took its toll on the light .
  15. Update: I re-examined the light again. The mercury switch didn’t look like it leaked. I couldn’t think of how it could go bad. I took sandpaper to the contact points and used pliers to bend the tabs. With the box held vertical, I have continuity on + and - wires!! I then tested the cord wheel to the light socket. Again, I used light sandpaper and contact cleaner spray to the contact disks. I have continuity on both wires. I put the two halves together and tested continuity from the + feed to the light socket. With the unit held horizontal it was open circuit. With the unit held vertical it has continuity. The - has continuity full time. Mercury delivers.
  16. Mercury switch. That’s the name. Are there aftermarket options rather than searching through JYs?
  17. Does anyone know the name of or part number for the gravity activation switch in the light box? I have a light that is in decent shape and want to get it working. I can get continuity before the switch and after the switch. The switch is supposed to make contact when the box is tilted up.
  18. If you have power locks and find that the driver's door just will not lock or unlock when you hit the switch, you should do this upgrade/fix to your wiring. I found this write up on both JeepForum and NAXJA.org. I will paste a link to the NAXJA since it is a little more concise in the write up. https://naxja.org/threads/greg-smith-power-door-locks-writeup-pre-1991.1874/ I followed Greg's instructions except for the power source. I spliced into the main power coming over from the driver's side and used a splitter from NAPA (part #784473). I cut the light green and tan wires and crimped on spade female connectors. These went directly to the relay terminals. I should have added more wire so the connections aren't as stretched. I did add wire to the power feed, as the photo shows. It isn't pretty, but you cannot see it with the kick panel in place. Verdict: DO IT! I now have working door locks from the driver's side.
  19. Thanks. So a regular bike inner tube will work?
  20. No, the topic is not a Johnny Carson "Carnac the Magnificent" sketch. My 4.0 has a bored out TB and the long term fuel trims according to the REM has risen to 135-140 (normal S/B 128). According to the RENIX Fuel Manual, an increased FT mean the engine is detecting a lean condition and is enriching the fuel mixture. I just installed a new MTS fuel pump/sending unit (see my earlier thread about the OE FP with a broken ground wire). I tested the fuel pressure and have 31 at idle and 39 with the vacuum removed. When I turn off the engine, the FP hold steady for 15+ minutes. The REM shows the O2 sensor working as it should - voltage rising and dropping from 1.00 to 4.98. Other things I found: When I remove the cap for the Schrader valve on the fuel rail, fuel leaks out. It does not leak with the cap on. Should it be leaking at all? The engine will idle around 750 +/-. It will periodically drop to 550+/- and stumble, but rises up again to 750. I cannot find any 'obvious' vacuum leaks that allows un-metered air in. Would the bored out TB, which is allowing more air, cause the rise in LTFT? (PS - it was operating within the normal range prior to the restoration. At that time, it had the old FP and the bored out TB.)
  21. I've seen this guy's videos on other vehicles and brands. A SHORT history of the Comanche.
  22. They know when the warranty expires.
  23. The clock fuse is only hot in run. The fuse that is hot at all times for the clock is the ETR. I would suggest you check the grounds for the radio. Cruiser was always harping on grounds. My experience was with the clock. It would sometimes display or display very dimly. I did Cruiser's instrument panel ground upgrade and the clock displays bright now. To quote the Beach Boys: "Ground, ground, get a ground, i need a ground." (or something like that.)
  24. If it smells like antifreeze, then your heater core is leaking. If it is just water, then there several possibilities, including all the options above. Check the condensation drain opening. From the engine bay, there is a pipe coming out of the firewall below and to the right of the blower motor. Disconnect the short hose (if still attached) and clean out the pipe.
