8
Location
Richmond, VA (or Pittsburgh, PA)
4318 profile views
mjeff87's Achievements
Obsessive Comanche Disorder (9/11)
Finally did the LBJ's in the KJ this weekend. On a 1-10 scale it was about a 5, only due to all OEM stuff that hadnt been touched in 25 years. PB Blaster was my best friend. I also replaced both outer TRE's just because I was in there. About 4 hours of work, $145 in parts and about 6 (ok, maybe 10) beers. She rides like a Cadillac now, lol.
Hey Pete, have you done LBJ's on your KJ before? I just ordered a set of them and am going to attempt to swap mine out this weekend (they appear to be originals, so getting them out is probably going to be tons of fun...). Any tips/tricks to them? I do have a decent BJ press tool, but it only has a couple collars and whatnot. I'll probably rent out the full kit from Advance or O'rileys just to have on hand if I need other pieces/parts.
74 (-ish?) Ford Maverick. I either bought it for like $50 and a six pack of Schmidt's or someone gave it to me, I don't remember which. Redid the carpeting in it when my grandmother ripped out her ancient green shag carpeting in the dining room and bought new stuff. Driver side bucket seat was trashed, I replaced it with a milk crate and a pillow. Not bolted to anything. Fun times... I eventually killed it (the transmission) trying to offroad it up on the mountain. Turns out pouring beer into a very overheated transmission doesn't work so well. It worked up until it didn't.
I ran 235/75/15's (on steel wagon wheels to boot) on mine when it was still a 2WD-2.5L, although mine had a 5 speed and 4.10's. It ran fine. Couldn't tell any difference between them and the stock 205's.
Isn't that one of the braces under the steering wheel/behind the lower dash that holds the steering column? I know I've seen that thing (or something very close to it) before, that's where my mind is taking me.
97+ aw4 to 88 ax15.. what do I do with the aw4 wiring?
mjeff87 replied to 0regon's topic in MJ Tech: Modification and Repairs
I used an HO auto engine harness when I swapped a 4.0/AX15 into my then 2.5/AX5 87 MJ way back in the day. I just disconnected the subharness that runs into the cab but had to jumper the NSS switch wiring for it to fire. I don't remember which pins they were though. edit: found an old post of mine about the wiring... "jump (or splice) the B and C pins on the NSS connector on the engine side harness (black wire and black/white tracer wire)" -
I need clutch advice please!
mjeff87 replied to TheMaddTitan13's topic in MJ Tech: Modification and Repairs
I would replace the clutch while you're in there. Also, if you're putting a new internal slave/throwout in it, ditch those cheezy little "U" clips that hold the lines into it and replace them with appropriately sized cotter pins. I've had those little clips fall out before...nothing says frustration like having to pull a transmission again to replace a .02c piece of hardware. Also, spend a minute with some emery cloth and clean up the tip of the input shaft where it rides in the pilot bearing (and install a new pilot bearing, which should come with your new clutch kit) -
First year KJ's (2002) had rear drum 8.25's. I know because I own one
Curved bracket xj bucket seats question
mjeff87 replied to Ricky8227's topic in MJ Tech: Modification and Repairs
Had them in my MJ. I didn't hate them, but I wasn't in love with them either. Yes, they do raise your sitting position up, which also does two things. It puts your head closer to the ceiling but even worse it reduces the space between the bottom of the steering wheel and the top of the driver seat. It makes it a challenge to slide your leg/thigh under the wheel when getting in/out. You can rock the seat the whole way down to help a bit with that, but you have to readjust it every time you get in. For reference, I'm only 5'8" (when I wake up in the morning anyway...), not a "big" guy at all. I did appreciate the higher sitting position though. -
I'm still around. Bumper sticker and windshield decal went away with the MJ but I've still got magnets!
I sold my MJ years ago, because I built it up to more than I could (legally) do with it and it became a garage queen. At that point in my life, it was the right time. Fast forward about 10 years and I'm again itching to tinker on something again just for fun. I'm in a different spot now. I do have the KJ, which is my little creampuff but is wholly impractical to turn into any kind of half serious wheeling vehicle (and I don't want to hack on it anyway). Ill probably pick up a beat to hell and back XJ to work on. Wife doesn't care, which is a bonus. She knows I have to be wrenching on *something* to be happy.
Wow. I've been AWOL around here for a bit (life/work stuff getting in the way) and just saw this. RIP Pete. His renix knowledge was unparalleled, and like his obit states he would jump in and help *anyone* that needed it. Truly a loss to the community, not to mention his family and friends. I can see him and Don sitting together on a patio table out by a lake somewhere in heaven right now, drinking beers and having a "gentlemanly discussion". Lol.
