terryt
717 profile views
terryt's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. Thank you
  2. is a valve cover gasket on a 1990 MJ 4.0 easy to do
  3. i know this has been asked a lot but what size stock rims on my 1990 comanche 4.0 2wd i think i have a bent rim and would like to replace with same size Does anyone have any 4 sale?
  4. i am installing an aftermarket radio in my 90 MJ can someone please help me with the wiring diagram please
  5. yes that is correct
  6. Could someone please help me with a radio that has a touchscreen and blue tooth prefer compatible with Apple i would rather not cut my dash up i would also want to change speakers 1990Comanche 4.0 5 speed
  7. Thank you all
  8. 1990 MJ My passenger floor is wet and thoughts as to why?
  9. I get it thanks for just thinking about it 5 speed new clutch flywheel
  10. The only thing i found is when i grab the steering shaft i can move it a little so i bought one and have not replaced it yet could that be it? When i put the brakes on it i packed the wheel bearings good but now that i think of it the right outer bearing didnt seem as tight as the others that being said why only at that speed would it do that?
  11. I have now replaced the harmonic balancer and from 45 to 55 mph it is vibrating still i have balanced wheels 2 times new tires. The suspension parts are all tight Its a 1990 MJ 2wd i replaced the rear u joint and the one in the front going into the back of the transmission seems fine. I am about to give up does anyone have any suggestions? At lower speeds up to 45 mph it is fine and 55 mph and above its fine Could the front u joint be bad even though it seems fine? I have also replaced the clutch and flywheel and brakes all the way around. PLEASE HELP IF POSSIBLE
  12. it does not someone told me to grind the cable going into the cluster which i did and it was perfect until it warmed up then it started bouncing so they said to grind it some more because when it gets hot it swells up any thoughts?
  13. Someone please help
  14. I finally got my speedometer by grinding the cluster end shorter it was as close to perfect as I needed until it warmed up now it bounces again I assume I have to grind it shorter? If so how do I know how much without risking breaking that plastic clip? This is my 3rd cable and I’d rather not buy any more thank you in advance
