Jtrux
    San Antonio, TX
1382 profile views
Jtrux's Achievements
Comanche Aficionado
Comanche Aficionado (4/11)
  1. Well, I've got the CDC in mine and they were far from perfect. If I had done a little more searching around I might have found the other floors. However, once the vinyl was reinstalled, you can't tell so it is what it is.
  2. I recently installed a GM crate engine in my brother's truck. Rather than risk any premature failures due to poor lubrication, I went ahead and bought Amsoil Z-rod oil which is designed to be run in these older, non-roller engines. Oil is cheap, engines are not.
  3. Well, I screwed up. I honestly figured that just getting the rockers replaced and having those areas repainted would make me a happy man...and I was right, however, I failed to realize that having perfectly-painted, factor- colored rockers would look just silly alongside the heavily-worn, original paint. I went to go pay the bill and pick up the truck today and was just blown away the new paint looked and flat out disgusted with the rest of it. Just in case anyone cares, I never had aspirations of making this truck a show queen and really had no issue with the look of it, other than the rusted areas, but after seeing that shiny paint, I just told him to paint the rest of it. It will look way nicer than I originally intended but screw it, you only live once. I'll update again once it's completed and finally show some pics.
  4. Here's the work in progress. The floor was rotten well up into the transmission tunnel so he had to hammer out some small panels to cover those areas up. Looks pretty good to me especially considering that it will be covered up with carpet. I can't wait to get this back and start driving it.
  5. I had a 302 I had envisioned installing in my MJ at one time. It should fit really well honestly. Front distributor makes firewall clearance a little easier than a Chevy and the short deck height makes hood clearance easy as well. Curious to see how it goes for you.
  6. Where do I find these little doohickeys? Radiator grommets that's threaded in the inside. It's for a 2.5L also. And where's the best place to buy a new steering shaft?
  7. To each their own.
  8. Yea, the quote doubled when I wanted to go to a different color. Still not opposed to it but it is something to consider for sure.
  9. Thanks. I should have mentioned that it's for a bench seat but I'm sure the answer is still the same.
  10. Are there any aftermarket companies making foam kits for these or is that a custom job? I literally don't know the first thing about interiors.
  11. Soooo, I am terrible at body work. I gave it the ol' college try and failed. In my defense, I work on it for an hour at a time and don't have a very good area to work in, so it makes doing detailed body work a little difficult. Coupled with the fact that I'm just not good at it. Anyways, I have reached out for some quotes on finishing it. Here's my current conundrum: do I get the whole thing painted after the rockers and floors are replaced or do I just have the guy shoot the areas that are seen and match it the best he can? I'm leaning towards getting the whole thing painted and if I do, the second question is do I keep with the original red or go with an all new color? More than likely I will wait until the last possible minute to make that decision. The first major thing to do once I get the truck back is get everything working. AC, heat, radio, etc. I'm daydreaming about an engine swap, as well. I have a 4.0/AX15 I could throw together and I also have a factory Dodge V8 AX15 bellhousing so a modern hemi swap is a possibility but I'm really leaning towards that little Cummins swap. From a practicality stand point, the 4.0 makes the most sense followed by the Cummins. Hemi is cool, but I don't know if I really want to deal with all of that. Let's get the truck sent off to the body shop first and then go from there.
  12. Any key chains?
  13. Just curious but how do you plan on having it terminate at the fender?
  14. I really need to finish this.
