Update, my 1987 comanche started to quit running again after 2-3 months running normal. same issue get up to 191 temp, before thermostat opens, engine dies. sometimes restart, sometimes, not. wiggled fuel pump relay wires it shut off. rewired temporary with spade connectors. then it would die begore i could get out of drivers seat and get to hood to wiggle wire connectors. frustrating. then i wiggled the new Siemens crankshaft position sensor plug, it died. cleaned the original
female connector, twisted it upside down to make better contact on the puns and ran 3 tests stayed running. ran a roadtest for over an hour, dudnt cutoff, i ordered a new female connector and fusible links from rockauto. everytime i touched a different connector the engine would die, replaced every one several times, it may finally be fixed to stay running, thanks for all the suggestion, its been very frustratinf to spend thousands of $$ and can't drive the comanche
