AMC86Kid
2 Followers
    AZ
1782 profile views
AMC86Kid's Achievements
Comanche Addict
Comanche Addict (5/11)
  1. i guess i will bypass it and see how it goes
  2. gas comes in on right side the front port is vacuum advance on a distributor and the left side ports i believe are for egr
  3. Yes the regular radiator hose felt hot and full on top of the radiator, I forgot to squeeze the one on the bottom
  4. So I finally got a chance to test out my mj after it's been sitting for like 4 months and the engine ran for about 20 min at higher rpms and started to overheat climbing over 220 I pulled over and stopped I noticed that the two lines to the heater core don't feel the same the red one feels full and the black one feels empty my question is will a clogged heater core cause a issue of cooling fluid to build pressure and get hot ? Should I by pass it and and test it out by passed ?
  5. You need to test the system when it’s blowing hot make sure clutch is engaged and the pressure switch is operating correctly otherwise it’s a wiring issue
  6. Yeah I know but I’m not gonna mess with that at this point I just need to pass emissions with the truck first
  7. If I start it at just one turn out then it won’t stay at idle and die off
  8. Ok I think I set it good now both screws are fully turned in and then backed out 1 and 3/4 of a turn and my idle is around 800 I think I’m good now, I might just have to reset the timing now to see if that makes a difference
  9. I put the Permatex Muffler/Tail Pipe Sealer and so far it holds real good so I slapped the clamp over it as an extra support, no leaks now I can tune my carburetor
  10. Ok so both front and back screw have to be turned the same amount so I got to change my current settings then cause right now there not even and screwing it in sends less gas threw right ?
  11. No I need to make it so that I can take it apart if I need to
  12. i still have a leak i gonna try to seal it with some exhaust sealant and the clamp thats on there https://www.acehardware.com/departments/automotive-rv-and-marine/auto-tools-and-maintenance/auto-body-repair/80355?store=14600&gclid=CjwKCAjwjLD4BRAiEiwAg5NBFn6gahiOQnpQSPq_BoueqPzF4auljn2i5bPgpPCd0TPz871rnlARDhoCHPgQAvD_BwE&gclsrc=aw.ds
  13. ok guys I'm trying to tune my carb i got the timing down to around 13 BTD at around 700 rpm but now I'm trying to tune the carb and I'm trying to understand the correct way to do it also the motor operational temp is around 180-190 does anyone have any tips or a link to a good video
  14. Around 2 inches
